Seat Belts...
Can anyone tell me if a 67-72 3 point seat belt can be mounted in a 64?
The wife is requesting a shoulder belt but I want to keep the bench. Thanks
1964 Chevrolet C-10 SWB Fort Worth, TX |
Re: Seat Belts...
Just about any truck seat belts can be added, mine are from a 98 Chevy.
![]() Join Date: Oct 2006
Re: Seat Belts...
They sure can. Punch in seat belt in the search and you can find older post on how to do it. Not to hard to do
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Re: Seat Belts...
How did you mount the shoulder? I'd prefer not mount anything to the pillar but I don't know of another way.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Seat Belts...
Re: Seat Belts...
Thanks!
Re: Seat Belts...
This link shows step-by-step installation of shoulder belts in pre-66 trucks ...
http://www.bobshotrods.com/howto/3-p...chevy-pick-up/ I recently installed 2-point belts in my '64 and two things I recall that I want to share. If you locate the belts using factory specs, the hole you need to drill next to the driver and passenger door are located over a mount, so you'll have to drill through both the floor and the mount, which translates into longer grade 8 bolts, I think they were 4" long. Second, be mindful of the gas line location under the truck, it's going to be really close to where you place the washer for the inner mounts. A final thought, if you're installing a center belt, drill separate holes for them as well, don't share bolts.
My truck ain't dead, it just smells funny. |
Re: Seat Belts...
Great advice. I have relocated the fuel line with the aluminum tank in the rear so I can avoid that issue.
