Old 01-15-2013, 03:08 PM   #1
Madtat
Madtat's Avatar
Heater control cables
I noticed the levers on my defrost and heat settings when set all the way to the right kind of move back a little. They do not stay at the far end of the setting. I have WD40'd the back of the levers and the cable where it goes into the cable housing but they still do not stay. Is there a way to adjust the cable to add more slack or decrese it?
If there is a thread on this please post it.
Thank you.
Madtat is offline   Reply With Quote
Old 01-15-2013, 05:56 PM   #2
1972SUPERSB
1972SUPERSB's Avatar
Re: Heater control cables
Thank you.
Mine do the same thing. Kinda move back on their own. I'm wondering on a fix also.
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 01-17-2013, 05:18 PM   #3
Lemield
Lemield's Avatar
My C20 has this same problem....does anyone have a solution to this?
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 01-17-2013, 05:27 PM   #4
Olive1970
Olive1970's Avatar
One of my levers broke off at the face of the controls, seems to stay in that position pretty well now
Olive1970 is offline   Reply With Quote
Old 01-17-2013, 05:37 PM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: Heater control cables
Well it been a while since I did this but here goes.
I was having the same problem and so I started taking the cables out of the truck completely. I then oiled the cables really good and hung them up for a few days and kept oiling everyday and after a week I reinstalled them.
They work well and never had anymore problems since.
You can also look at where they attach to the housing and adjust them a little.
The drawing is for non AC trucks but it'ss the same basic thing for either.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-17-2013, 05:44 PM   #6
Madtat
Madtat's Avatar
^^^^ Thank you Andy4639!
Old 01-17-2013, 05:48 PM   #7
Andy4639
Old member
Andy4639's Avatar
Your welcome!
Old 01-17-2013, 05:50 PM   #8
Lemield
Lemield's Avatar
Yes, Thank you Andy4639.
Larry
Old 01-17-2013, 05:54 PM   #9
Andy4639
Old member
Andy4639's Avatar
Talking Re: Heater control cables
No problem!
Make sure you work the cables good while they are hanging. Pull them back and forth to get the oil into the slleeve. Pull one end all the way tight then put the oil to it while you pull it back the other direction to help feed the oil into the sleeve.
