Old member
What do you think?
I have the Ram horns on my truck now but found these for $100.00. Would it be worth swapping them out. Good and the bad comments welcomed. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#2 | ||
"I ain't nobody, dork."
Re: Headers
You will see no performance benefit from using headers that short. They are a nice ceramic coated set that will look good in your engine bay. But the Ram horns will probably flow just as good.
Gary
Re: Headers
I would only change to these from stock if they are ball/socket at the collectors and 3/8s flanges. Otherwise you'll be chasing leaks.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Old member
This is what I want to know. I figured this to. I can get my horns coated I guess and come out better.
