01-10-2013, 09:36 PM | #1526 | |
Re: Make it handle
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
01-11-2013, 10:58 AM | #1527 | |
Knuckle head
Re: Make it handle
-Adam
Adam '71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750 2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC '00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed '09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD) 1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785 1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis. |
01-11-2013, 06:23 PM | #1528 | |
Re: Make it handle
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
01-14-2013, 09:44 PM | #1529 |
Re: Make it handle
was thinking about this thread today and front upper/lower a-arms......not sure if its been covered....is there an ideal relationship to the ground for best handling? i.e. flat (parallel to ground), pointed up, pointed down?
01-16-2013, 12:16 PM | #1530 |
Re: Make it handle
SUB'D this is a awesome page a lil over my head but i am trying to learn how to make my truck turn a corner
70 C10 working on a LSx swap 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
01-17-2013, 01:15 PM | #1531 |
Re: Make it handle
I usually try to keep the lower A-arm level to the road. This would be the line from the center of the pivit bushing to the pivit center of the ball joint. - this ma bee a bit different than the arm itself. On street cars, I would want to just a bit more spring hieght, with the ball joint slightly lower than the bushing, and for a track set up, just the opposit, with the ball joint slightly higher. All of this would be within 5 degrees of being level.
01-17-2013, 03:35 PM | #1532 |
Re: Make it handle
I want to see these pics of Hellboy with the road course spoiler!
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
01-17-2013, 07:56 PM | #1533 |
Re: Make it handle
These wheels are amazing! Truck looks great Rob! Very impressed.
01-18-2013, 11:59 AM | #1534 |
Re: Make it handle
Rob, the pic you posted on Facebook of Hellboy in downtown Portland is one of my favorite truck pics. I love everything about that truck and to see it in my part of town is awesome.
01-18-2013, 02:50 PM | #1535 |
Re: Make it handle
I'd give my first born for those wheels.
Posted via Mobile Device |
01-18-2013, 02:59 PM | #1536 |
67cheby
Re: Make it handle
that is a SUPER COOL PICTURE
01-18-2013, 06:56 PM | #1537 |
Re: Make it handle
put my 1 1/4" bar on and replced the control arm bushings with energy suspensiond black bushings. i just need to test it out lol. DARN YOU ICE
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
01-18-2013, 11:42 PM | #1538 | |
Re: Make it handle
01-19-2013, 03:42 AM | #1539 |
Re: Make it handle
my truck feels 100 times better after the bushing replacement, i talked t a local guy about how he builds his panhards. he owns a small shop just minutes away, i may by some parts from him
01-19-2013, 03:47 AM | #1540 |
Re: Make it handle
01-19-2013, 05:02 AM | #1541 |
Re: Make it handle
I saw on you JT truck that you placed the panhard pretty far off center of the axle. Does this have an effect turning one dirrection or the other? If so is there a good compromise between lateral location on the axel and rod lenght?
PANHARD BEFORE REAR SWAY BAR Would you suggest adding a panhard bore a rear sway bar? Sounds like circle folk mount the panhar bar to the left side of the frame so the panhard bar gains a downward angle when cornering. Would this have a noticable effect when not combined with a rear sway bar?
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread Last edited by cory d; 01-19-2013 at 05:25 AM. |
01-19-2013, 12:46 PM | #1542 | |
Re: Make it handle
Sway bars are the best bang for the buck upgrade. But these other items need to be addressed at some point to get the best out of the truck.
01-19-2013, 02:42 PM | #1543 |
Re: Make it handle
Rob,
Been a lurker here for awhile, really enjoy reading your thoughts/direction and teachings (as well as other mfg. in put), then dreaming how to apply to my application 68 c10. The wish list is growing. On post #1516 the bore size 13/16 X 3/4 you talk about, would this be true for hydro boost system? You also mentioned on another post that you were getting a set of Porter lower a-arms for JT, have you had a chance to install and see what alignment you ended up with? Thanks in advance for your time. Greg in Fresno, CA |
01-20-2013, 02:23 PM | #1544 |
Re: Make it handle
For a hydro I use a 1 1/8" bore master, hydro boosts make so much pressure you need a big bore to calm them down.
Yes, we did put a set of Porterbuilt "forward" lower arms on the JT. It was easy to get the caster in the 6-7 range. Drives great. Look for an article in Street Trucks.
01-22-2013, 12:57 AM | #1545 |
Re: Make it handle
I'll just hunt the junk yars for a 7/8 " bar that will work with my frame width then for $20 (yay being 21 and unemployed lol). and see what i can do with it
01-22-2013, 06:41 AM | #1546 |
Old member
Re: Make it handle
I like the picture Rob! Very
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-22-2013, 02:41 PM | #1547 |
Re: Make it handle
Hmmm.............a BFGoodrich sticker.....................but with Falken tires mounted.
01-22-2013, 05:51 PM | #1548 |
Re: Make it handle
HAHA, Falken in the front, BFG's in the rear. May not have been my best decision. The Falken's are stickier but the balance was off. I was going to run all four Falkens, but we discovered a leak in one at the last minute. I probably should have put all of the BFG's back on, thats what I was used to.
01-22-2013, 06:58 PM | #1549 |
Re: Make it handle
Wow! what a truck man. I am going to go through this thread and try to see what you guys have been talking about in here. This is a subject that I am very interested in. I am coming from racing spec miata's. So, it will be very interesting to see how you guys are setting up these trucks.
01-23-2013, 08:19 AM | #1550 | |
Re: Make it handle
