removing ignition switch
What else do you need to do to get this thing out? I have loosened the bezel, but it's still hangin in there.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
key and paperclip in the little hole.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
GREAT!! thanks for the replies guys
hmmm just went outside and tried it, but it wouldn't come out
dubie,
Try using some liquid graphite in the lock. Squirt some in and work it with the key, then leave it sit to dry. Then try the tip on GMC Pauls site. The liquid graphite works into all the spots that gum up.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
let me guess it is probably a 67 or 8 it seems like these just dont want to come out I dont have an acc to the left so that seems to be the kicker? anybody else help here?
Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
With the 67 type ignition you just use the paper clip plan in the off position and push the clip in and rotate left.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
its all about the +6 inches
Yup. That's how i got Jeweles' 68 ignition switch out. It just takes some messing with and some sweet talkin.
A few choice words never hurts...........
I think that's why it's not coming out, i must have offended it already
#12 | |
![]() ![]() Thanks Dave
I just tried it ....without swearing, and it came out
C/10 CLUB MEMBER
![]() Join Date: Jul 2003
whooo hooo, way to go now it's my turn...
-Ron- ![]() |
#15 |
![]() Join Date: Feb 2001
Its all in the lips and how they are formed! Don't cuss it!
#16 |
I also gave it a tiny shot of WD 40
#17 |
You mean cussin isn't sweet talkin?
Wow...how the hell did I get married? I thought I was sweet talkin her. ![]() |
#18 |
helpppppppp
I am bringing this back up I still can not get mine out. it is a 68 that has no accessory spot to the left (CCW) but that may not matter. I worked and worked on it last night and still can not get it out. The good news is that I did spray enough WD-40 to get my switch working really good
![]() ![]() Signed, frustrated in MO Dave
#19 |
Does the key slide out of the ignition switch in any position? I have done a few like that, and I found that a small bent screwdriver workd pretty good. I ise the paperclip or whatever and get the thing inside to depress, then I'll slide the key out and insert the small bent screwdriver. Kinda pull against the face plate (if that's what you want to call it) and it might come out.
That's what i had to do to get Jewles' switch out. |
#20 |
OK Andy yes my key will slide out in any position running or what ever. So you just need to put the key in press on the spring in the little hole (I used an allen wrench) not turn the key and just work on getting the outter ring off? Sound right? I will try this...again
![]() Dave
#21 |
Here is what i did:
my key comes out in any position on my 70, so what i did was remove the bezel and pull switch, lock and everything out from behind as a group. then i unplugged the harness from it. i tried everything to get the dang lock out of there. after about 20 minutes of yellin i broke down and went and bought a new lock and a new ignition switch. but then i couldnt get the bezel to go over the lock from oreilly (the key says gm car... hmm? wrong part?) so i went over to my trusty sander and sanded it till the bezel went over it. AFTER ALL THIS i still could not turn the truck off using the key. that was the original reason for pulling it all out, see. now, when i wanna turn the truck i have to go under the hood and pull the power cable thingy off the hei distributor
70 longbed 496/th400/Ford 9" |
#22 | |
Psycho-billy Member
Where is the hot wire to your hei coming from?
'72 C-10 350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers. Support your community, support yourself. Buy local, buy American ![]() |
#23 |
Yeah, if the parts are correct, you won't be able to pull the bezel off over the ignition switch.
