Old 01-20-2013, 10:06 PM   #1
79Betty
79Betty's Avatar
Question Heater Core Probs... Again!!
Hey guys just me again... Ha. On betty (my 79 k10) the heater core started leakin. Well i replaced it with one from the parts store n the little tabs/ bolts on the top n side broke which where my problems began. i got a different box n well the heat isn't hot and it has all good tabs... It's Not rven warm. I ended up running hoses from the intake to water pump hopen to get hot water and it still didn't nothin. I'm to the stumped point anymore.
79Betty is offline   Reply With Quote
Old 01-20-2013, 10:17 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Heater Core Probs... Again!!
Was this new core alujerbin? Or copper? You want the flow to go from the bottom to the top so it blows out any air bubbles. Is your truck a/c equipped or once was?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-20-2013, 10:41 PM   #3
79Betty
79Betty's Avatar
Aluminm core, and non ac... Kinda sucks a/c cab parts are a lot more common round here
Old 01-20-2013, 10:53 PM   #4
INSIDIOUS '86
Ok aluminum heater cores are real bad they conduct heat horribly. You need a quality copper style one. That may be part if the issue
Old 01-20-2013, 11:18 PM   #5
79Betty
79Betty's Avatar
Ill head to the oarts store morrow then... Hooe this solves it the high is 29 degrees tomorrow n lookin like the rest of the week.
Old 01-20-2013, 11:26 PM   #6
INSIDIOUS '86
Yah so after this make sure the water exits the top and make sure the engine is fully warm. Also make sure the blower is working
Old 01-20-2013, 11:30 PM   #7
86c20
86c20's Avatar
,ake sure your heater lines are right from motor and back. water pump is sucktoin intack is pressore
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 01-21-2013, 07:17 AM   #8
79Betty
79Betty's Avatar
I'll hook em up like that too hope it all adds up to somethin workin!
Old 01-22-2013, 07:23 AM   #9
79Betty
79Betty's Avatar
Little insight. Can't buy a copper core, no surprise there. I put a 195 thermostat in it hopin to get it hotter, no change... Routed my hoses the 3/4 from intake to top 5/8 from bottom to pump. Still nothin.
Old 01-22-2013, 09:59 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
what is your anti freeze rated too
were getting -29C this week here ...sure your not icing up?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-22-2013, 10:01 AM   #11
79Betty
79Betty's Avatar
It's a 50/50 mix of o'reilly green stuff. One gLlon full one gallon water then top off half/half pre-mix. Says -40c to i think 250? Not for sure.
Old 01-22-2013, 10:28 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
i'd get the tester to confirm,too much/too little anti freeze would get slushy,or worse
John
Old 01-22-2013, 04:01 PM   #13
79Betty
79Betty's Avatar
It's tested good about 60/40 honestly i flush it twice a year.
Old 01-22-2013, 04:48 PM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
lol don't need to be honest with me,just your truck
twice a year?...why
John
Old 01-22-2013, 05:47 PM   #15
tucsonjwt
Go with copper. You can order AC Delco or GM OEM online at cheap prices and free shipping.
Make sure you have the correct thermostat in your truck and that it is opening, not stuck shut.
tucsonjwt is offline   Reply With Quote
Old 01-22-2013, 06:05 PM   #16
79Betty
79Betty's Avatar
I just put a 195 in it last night literally lol. And i'll look tonight for a copper ine
heat, heater core, hot
