01-19-2013, 02:32 AM | #1 |
Wiper Motor Gasket Help
Getting ready to install a wiper motor in my 67. I picked up a new gasket from Brothers. Do I install it dry with the gasket or do I use some sealant on it? If so, from gasket to cowl or gasket to motor or both?
Any other tips? Thanks, Adam Posted via Mobile Device |
01-19-2013, 08:13 AM | #2 |
Re: Wiper Motor Gasket Help
No sealant that I know of. Should be made of a tar like substance. Just slip it over the shaft, should kinda stick, then install the motor. Tightening the screws will squish it to make it seal.. All from the inside
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
01-19-2013, 09:55 AM | #3 |
2WD Jimmy
As I recall, I used a dab of Henrys Plastic roof cement on both sides of the gasket just to make sure. Its black and kind of soft like the gasket, so it looks right and will insure no leaks period.
01-19-2013, 11:02 AM | #4 |
Active Member
New seal I got was rubber and I used sealant on mine. It is a good area for water to seep in undetected (like mine) so why take a chance.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
01-19-2013, 07:03 PM | #5 |
The new one is a rubber type of seal. Maybe I should put a little on just for good measure. I'd rather not take it apart again to reseal it because I didn't. Unless someone has a reason why I shouldn't...
Adam |
01-19-2013, 07:39 PM | #6 |
A Little precaution doesn't hurt..
01-22-2013, 01:55 AM | #7 |
I did put a little black RTV around the edge of the gasket. Probably not necessary as this new gasket is cut much tighter around the wiper motor than the original. Same size outside dimension, but this one is tight enough that I had to have the arm off the motor to slip it on. I think it will seal well, and a little extra didn't hurt.
Thanks guys. Adam |
01-22-2013, 09:22 AM | #8 |
Whoever sold you guys a rubber windshield wiper motor seal has done you a disservice as the rubber seal will quickly dry out crack & shrink from the underhood temps they become subjected to leading them to leak. The wiper motor seals should be a fiberous type seal thats impregnated with a tar like substance as the fiboruos portion is designed to withstand the high temps in the area of the wiper motor and the tar like substance its impregnated with is designed to seal it to the firewall & motor. Those rubber seals generally crack within the 1st year of use leading to air & water leaks.
Paul Jr @ GMCPauls |
01-22-2013, 10:17 AM | #9 | |
Adam |
01-22-2013, 10:29 AM | #10 | |
