Old 01-14-2013, 09:27 PM   #176
canadian 4x4
canadian 4x4's Avatar
Re: 1978 GMC Sierra C35 "Project Second Life"
the front end of my truck was a about and inch higher when i put in my 4.5/6 drop belltech kit. i put about 500 miles on the truck and the front springs settled alot and it has leveled out.
85 swb c10 6/6 drop
83 c10 bagged and sfbd project
canadian 4x4 is offline   Reply With Quote
Old 01-18-2013, 12:13 PM   #177
tc4x4
tc4x4's Avatar
Well thanks for the responses guys. Ill have to do some research. I want to continue with the build but I don't want to be able to be stuck not being able to drive it. My wife and I like our summer rides.
Project Second Life----1978 c35
http://67-72chevytrucks.com/vboard/s...d.php?t=503961
tc4x4 is offline   Reply With Quote
Old 01-19-2013, 12:23 AM   #178
kustomrust82
kustomrust82's Avatar
Originally Posted by tc4x4 View Post
Any ideas on where to get a poly bushing kit?
i got mine from energy suspension the whole kit for my swb was like 150, control arm bushings body bushings trans mount eaf spring bushings and tierod boots
'82 c10 shortbed drag truck
'82 GMC 3500 Dually DD scrap truck
'55 Chevy 210 4 door sled
'65 VW Bug Rat Rod
kustomrust82 is offline   Reply With Quote
Old 01-19-2013, 12:26 AM   #179
moregrip
moregrip's Avatar
subscribed!
moregrip is offline   Reply With Quote
Old 01-21-2013, 11:11 PM   #180
tc4x4
tc4x4's Avatar
So I am going to go forward with the front end drop? Any suggestions for drop spindles to get the most drop and also drop springs. I am going to try to get it as low as I can with out hitting the inner fenders.
Question, what size tires are people running with my size drop because I'm pretty sure that with how low im planning on going to finish this drop that the tires will be running.
Old 01-21-2013, 11:31 PM   #181
notallthere
I am running 275/60 r17 with a 2 inch drop on the front of my C20. I should be able to go another 2 inches with spindles this summer without issue.
notallthere is offline   Reply With Quote
Old 01-21-2013, 11:43 PM   #182
tc4x4
tc4x4's Avatar
http://westernchassisinc.com/shop/73...e-1-ton-truck/
Ok here are spindals for 3'' drop, now how do I get another 3'' of drop or maybe squeeze 4'' drop. I have nine in the rear, and need 7 drop in the front. I'm pretty sure that I won't be able to run these tires.
What are the drop amount on these two different coils? Can't seem to find it.
http://www.summitracing.com/parts/ws...olet/model/c30
Old 01-21-2013, 11:50 PM   #183
notallthere
The top ones are a three inch drop and the bottom is a two inch drop. If you hit the application button it puts the amount of drop on one of the lines. Any more then that I would be getting the drop lower control arms as well from DJM. So spindles would be 3" springs would be 3" or 2" and the DJM drop arms are 2"
Old 01-22-2013, 09:52 AM   #184
SCOTI
SCOTI's Avatar
3" spindles
2-3" spring drop (1 cut coil or drop spring)
1.5 crossmember drop
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-22-2013, 12:56 PM   #185
tc4x4
tc4x4's Avatar
So would 7 inches of drop be to much? That is the question? Also can someone educate me about cross member drops. I don't know anything about them. Pro's and con's.
Old 01-22-2013, 03:31 PM   #186
SCOTI
SCOTI's Avatar
Is 7" of front drop "too much"? Everything depends on tire height & wheel dimensions once you exceed 4-5" of drop w/OE wheel wells.
The crossmember drop raises the pivot points of the upper & lower control arms in relation to the remainder of the frame. Depending on how you combine parts, you'll get more drop or more clearance under the crossmember @ certain drop heights....
http://67-72chevytrucks.com/vboard/s...ad.php?t=60649
Pros: If you can fab (weld), it's possible to build one in a day from a spare. Fabbing your own stuff = less expense.
Cons:
It requires some creativity on steering (upper a-arm interferes w/the steering shaft; crossmember lip & mounting hardware might require some clearancing depending on the parts combo).
It's a PITA to do w/the drivetrain installed.
It compromises the OE steering more than it already is (whether or not you would notice is subjective @ best).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-22-2013, 03:37 PM   #187
CrazyDave
CrazyDave's Avatar
Glad to see ya didnt sell it that truck of yours is what gave me the idea to do
a heavier truck. Gotalot of ideas just havent got started yet.
Keep it going
David Fultz - Berlin Ky
79 K5 2wd - Project
86 GMC 1500 LWB- Shop Truck
84 Chevy K-20 Hugger Orange and Silver- Wifes Truck
2018 Ram 2500 - Tow Rig
79 Chevy C-30 SRW- Bought new by Uncle
CrazyDave is offline   Reply With Quote
Old 02-18-2013, 09:32 PM   #188
tc4x4
tc4x4's Avatar
What companies out there are reputable?
Do they sell complete kits for all I'll need?
Pros and Cons?
Can you post up some build links of trucks that used bags?
I know nothing about them but in the long run of my build want to do a complete bag setup. I think it will be nicer by far than a static drop. Especially on my Michigan roads.
Go.....
Old 02-18-2013, 10:20 PM   #189
tc4x4
tc4x4's Avatar
Accuair for the air system.
I'm thinking Porterbuilt for the front drop member.
But who makes a rear set up for a one ton. I did not see one on porterbuilt site...
Old 02-19-2013, 01:03 AM   #190
tinydb84
tinydb84's Avatar
This^^^
Suicidedoors sells a heavy duty four link kit. You would have to piece it together with a bridge kit though.
Old 02-19-2013, 09:38 AM   #191
SCOTI
SCOTI's Avatar
Ride Tech, Porterbuilt, No Limits, or Scott's are all board supporting choices too....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-20-2013, 05:43 PM   #192
tc4x4
tc4x4's Avatar
I really like porterbuilts stuff. I see the front drop member will work on c30's but do they have anything for the rear end? It appears to only work on c10's. Am i wrong?
Old 02-20-2013, 05:49 PM   #193
SCOTI
SCOTI's Avatar
Bolt-on stuff is C-10/20/30 front only. Check w/them for something else on the rear. All those suggested prob have a weld-in 'universal' HD type kit that would fall within you needs (I know Ride Tech does).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-01-2013, 09:53 PM   #194
tc4x4
tc4x4's Avatar
On a different note, I wanted to do a transmission swap, this 4 speed with the granny gear is way to low for when its back on the road just cruising. Keeping in mind the engine will have mild mods for awhile at the most, what would be a good tranny swap?
Old 03-01-2013, 10:16 PM   #195
tc4x4
tc4x4's Avatar
http://www.jegs.com/i/Edelbrock/350/...d=#moreDetails
Thoughts....
Old 03-01-2013, 11:10 PM   #196
MTCK
MTCK's Avatar
NV4500 if you like 3 pedals, 4l80e if not.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-02-2013, 07:23 PM   #197
tc4x4
tc4x4's Avatar
Will the NV4500 tanny bolt up with my engine?
Old 03-02-2013, 07:28 PM   #198
old yelr
Yes, it's the same bolt pattern.
old yelr is offline   Reply With Quote
Old 03-02-2013, 11:08 PM   #199
tc4x4
tc4x4's Avatar
How will it hold up to more power with engine mods.
I'm guessing it has overdrive?
Anyone have pictures of transmission cross members for the NV4500?
Anyone ever do this swap?
Will the shifter line up with the existing shifter hole in the floor?
Old 03-03-2013, 12:13 AM   #200
old yelr
Yes, it has overdrive and it should take a good amount of power. Do a search for member DirtyLarry, his thread is called "NV4500 swap is underway", that should give you a good idea of what's involved, lot's of pictures and explanations. He's running a big block in his blazer so it would be a good comparison for you. The NV4500 started being used in 1991 in 1 ton crew cab square bodies and continued to be used through the 1990's with the next generation of trucks so the parts are out there.
