Closed Thread
Old 01-22-2013, 09:14 PM   #6851
TxRat
TxRat's Avatar
Re: What did you do to your truck today?
welding up patches in the drivers door. found a good hood for my truck and found a high hump that I want to let go of...
TxRat is offline
Old 01-22-2013, 10:47 PM   #6852
dantimdad
dantimdad's Avatar
Figured out I could save the driver side door. Just need to patch the bottom not replace the whole thing.
So, I took measurements, drew an outline of the profile and cut out the rust.
Should finish it up this weekend and start on the passenger side door.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 01-23-2013, 08:57 PM   #6853
ABX131
ABX131's Avatar
We have a heater that works now! Replaced the fan motor which had seized, tore apart the fan switch and cleaned it up with a dremel tool, and ran new wiring. Moved back the radiator and installed the fan shroud, which seems to have solved our overheating issues...very productive couple of days. Still need to order some new heater control levers and knobs but at least everything works now.
ABX131 is offline
Old 01-24-2013, 07:32 PM   #6854
ABX131
ABX131's Avatar
Grandpa was able to repair the original sending unit! We now have a functioning gas gauge. I have two more I will let him take a crack at.
ABX131 is offline
Old 01-24-2013, 09:11 PM   #6855
LVPhotos
LVPhotos's Avatar
Pulled the Heater out the other day for a member in need. So today I cleaned up the atifreeze and did a quick polish. Ran into some loose screws but I did tighten the loose bolts on the truck. Checked for leaks where the pipe plugs were installed. Fluids and fuel pressure were good.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 01-24-2013, 10:07 PM   #6856
E911manager
Wiring and trouble shooting some funky lighting issues.. Worked out a crease on the inside of my passenger door.. But dash is working. This pic is with the truck running..
Oh do you think those caprice headlights will look good in the grill.. Kidding..
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline
Old 01-25-2013, 08:49 PM   #6857
E911manager
Got the headlights and brake lights working and had the windshield installed..
Old 01-26-2013, 04:55 PM   #6858
tincan1966
tincan1966's Avatar
After over 2 months sitting outside, finally pushed the 'Burb into the shop today, may actually get something done to it.
tincan1966 is offline
Old 01-26-2013, 05:10 PM   #6859
E911manager
Worked on a door and started making a plan to move the battery and placement of the AC dryer and AC hoses..
Old 01-26-2013, 06:04 PM   #6860
Hx16457
Hx16457's Avatar
Installed hood with hood/cowl seal! Fun fun my wife helped me set the hood!
Heavy and hurry is all she was saying, after she dropped both her bolts! Haha
Making memories! It makes her feel good when she can help, and she is good help!
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline
Old 01-26-2013, 06:44 PM   #6861
Trsmotrhed
Trsmotrhed's Avatar
What a project you're taking on. Looks good. I took my LT1 chevy truck out for another test ride today and will need posi for sure. You'll love how they run.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 01-26-2013, 06:48 PM   #6862
Trsmotrhed
Trsmotrhed's Avatar
Took the truck out for a cruise with the LT1 finally running and can't believe how this thing runs. I've had some warmed over 350's before and this runs so much better. Love the fuel injection. Starts and runs awesome. Here's a pic with engine running and one of me trying out the excelleration. From the pic you can see I need positraction. Picked up a ford 9" rear end with disk brakes, 5x5 lug pattern to match front. Time to install a posi unit and get it under the truck. I had done this same swap with the 9" on a 66 C10 and loved it.
63 SWB C10
Old 01-26-2013, 07:27 PM   #6863
Clyde65
Clyde65's Avatar
Installed the drop hitch, ran the wires to the new plug on the truck. Replaced the trans cler lines (old and cracked).
I'm trying to get Clyde ready to pull my 69 Aristocrat Lo Liner.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 01-27-2013, 08:54 PM   #6864
Hx16457
Hx16457's Avatar
Got all the body parts on finally, not done yet but she looks done!
Hx16457 is offline
Old 01-27-2013, 09:52 PM   #6865
mud.man.rj
mud.man.rj's Avatar
Interesting paint job, kind of like it being different. Cool idea.
mud.man.rj is offline
Old 01-27-2013, 10:16 PM   #6866
markeb01
Senior Enthusiast
markeb01's Avatar
Man that looks nice!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 01-27-2013, 10:48 PM   #6867
Vernski
I like it, you know it reminds me of a 56 chevy two tone paint job. If that's a rail cap on your tailgate [don't know if I'm seeing things] where did you get it?
most of the ones I find are for the newer pickups thanx...Vernski
Vernski is offline
Old 01-27-2013, 10:58 PM   #6868
Hx16457
Hx16457's Avatar
It is a Stainless cap, for our trucks and I got it from Borthers! They were the only one that had a fleet side cap!
The paint scheme is airbrushed and it mimics the 56' Nomad! I was really nervous about doing the airbrushing myself but, I really liked how it turned out!
I like it mostly because it is different & I did it myself!
Hx16457 is offline
Old 01-27-2013, 11:06 PM   #6869
racecougar
racecougar's Avatar
More cutting, welding, and flanging. Out with the rust, in with the patch panels.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline
Old 01-28-2013, 12:23 AM   #6870
Narxoleptic Customs
Finally got the 700r4 crossmember bolted up... Ordered a speedo... Now to get it to the trans shop to finish it...
Narxoleptic Customs is offline
Old 01-28-2013, 12:25 AM   #6871
Narxoleptic Customs
Old 01-28-2013, 02:50 AM   #6872
hemifalcon
This part is basically done..
And so I started this mess..
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline
Old 01-28-2013, 10:25 AM   #6873
65Gregg
65Gregg's Avatar
I wired my parking lights to come on/stay on with my headlights. It changes the appearence at night, I like the way it looks.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 01-28-2013, 11:13 AM   #6874
TehNewGuy
TehNewGuy's Avatar
Yea man I like the way those lights took at night with both on, I got to get around to doing that.
Got her running!!! Took her for a test drive to fill up the tank and then off to a buddies house to figure out the roof issues, ran great! After all that I went over to the parts truck and stripped it of fenders and the wiper cowl and then laughed as my dog got in the engine compartment and couldn’t figure out how to get out!
1966 Chevy C10 LWB Fleet- Project
TehNewGuy is offline
Old 01-31-2013, 10:49 AM   #6875
robber grin
Went to my buddy Harry's house to check the progress on the wood for the bed...
It's planed down rough cut 2" x 10" 100 year old Southern Yellow Pine that was used in the roof system of the old Westinghouse factory buildings in East Pittsburgh, PA.
I bought it off a guy on CL that had been reclaiming and cleaning it to sell... reasonable.
Harry said it was hard on the planer!
He didn't like the nail holes either, but I think they add to the story; besides once it's in varnish they will all be pretty well filled in.
Next Harry's going to make final cuts and groove to GMC Paul's blueprint...
I love the grain and the deep colors.
rg
robber grin is offline
Closed Thread
