Old 01-22-2013, 01:53 AM   #1
5150
C10 Club Tennessee
5150's Avatar
Did Burb's only have two piece driveshafts?
Was just wondering if that is the only thing they came with? I have a 2 piece shaft and my burb is bagged. I have a 4L60E so I'm going to have to have it shortened a few inches. Was just wondering about the one piece.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 01-22-2013, 06:51 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Did Burb's only have two piece driveshafts?
Yes, the suburbans all had 2 piece drive shafts, at least the 2 wheel drives. I don't know about the 4wd's but I would presume they all did too.
LockDoc
Leon
Old 01-22-2013, 08:03 PM   #3
rockc
4 wheel drive have 1 piece.
Rock C
72 chevy 3/4 ton 4X4
rockc is offline   Reply With Quote
Old 01-22-2013, 08:41 PM   #4
LockDoc
LockDoc's Avatar
Rock C
Thanks for the update on that.
LockDoc
Leon
Old 01-22-2013, 11:13 PM   #5
5150
C10 Club Tennessee
5150's Avatar
Learn something every day.
Trying to decide if the original drive shaft can handle the 5.3. Not doing anything special to the motor so I think it should. Just get it shortened a few inches, install all new U-Joints, a new Carrier Bearing, and slap it in.
Bryan
www.gmtruckshow.com
Old 01-30-2013, 12:29 PM   #6
ERASER5
ERASER5's Avatar
The drive shaft is plenty tough for 5.3L. U-joints should be checked though.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-30-2013, 12:54 PM   #7
Keith Seymore
Keith Seymore's Avatar
Two piece shafts were employed to stay out of the driveshaft "critical speed" range: the point at which the shaft starts to bend and swing around like a jump rope.
Critical speed is a function of shaft material and diameter, length (longer is worse), rear axle ratio (higher numerically is worse) and vehicle top speed.
You can control all of that stuff in this case, so I'd recommend a one piece.
I always use a one piece shaft whenever I can get away with it.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-30-2013, 06:53 PM   #8
magicoolbus
magicoolbus's Avatar
My burb is 4x4 and has a 2 piece DL.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 02-04-2013, 08:01 PM   #9
rockc
My burb is a 4X4 - 3/4 ton and 205 transfer case.
Old 02-04-2013, 08:35 PM   #10
vectorit
What?
vectorit's Avatar
Rock C
My '68 K20 has a 2 piece drive shaft.
From all of the 67-72 burbs I have seen, whether in person or in documentation all 2 wheel or 4 wheel drive were 2 piece drive shafts.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-05-2013, 01:33 AM   #11
CrewCab59
CrewCab59's Avatar
My 72 k20 Burb has 1 piece 4" shaft , same as all my other 3/4 4wd .
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
