Old 01-23-2013, 10:11 AM   #1
Hart_Rod
Hart_Rod's Avatar
LS motor angle questions????
What part of the motor/transmission are you guys using to determine your motor angle? The back of a head? Transmission output shaft? Thanks in advance.
r
Hart_Rod is offline   Reply With Quote
Old 01-23-2013, 11:46 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: LS motor angle questions????
r
You want to use the face of the output shaft of the trans where the seal goes.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-23-2013, 12:11 PM   #3
Hart_Rod
Hart_Rod's Avatar
Nate
Thanks Nate. I thought I had read that, but I wanted to make sure before I drilled any holes. What's the max and min angle when setting this?
Old 01-23-2013, 12:15 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
3 is pretty ideal, and don't go past 6.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-23-2013, 12:21 PM   #5
Hart_Rod
Hart_Rod's Avatar
Cool. Forgot to mention, I will be running a 2 piece driveshaft.
Old 01-28-2013, 09:09 AM   #6
Hart_Rod
Hart_Rod's Avatar
Nate do you have any pictures or part number of the carrier bearing I should run with the 2-piece drive shaft? TIA
