Location: On the banks of the Clackamas River, Eagle CreeK Oregon
For all my buddies that like to tinker!
![]() Interesting! Even if you're not mechanically inclined, this might be worth noting. "Machinist's Workshop" recently published information on various penetrating oils. The magazine reports they tested these products for "break out "torque" on rusted nuts and bolts. A subjective test was made of popular penetrating oils, with the unit of merit being the torque required to remove the nut from a "scientifically rusted" bolt. Average torque load to loosen nut: No Oil used ........................516 foot pounds WD-40 ..................... ........238 foot pounds PB Blaster .........................214 foot pounds Liquid Wrench ......................127 foot pounds Kano Kroil .........................106 foot pounds ATF/Acetone mix...................... 53 foot pounds The ATF/Acetone mix is a "home brew" mix of 50/50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test. Our local machinist group mixed up a batch, and we all now use it with equally good results. Note also that Liquid Wrench is almost as good as Kroil for 20% of the price. ATF/Acetone mix is best, but you can also use ATF and lacquer thinner in a 50/50 mix. ATF = Any type of Automatic Transmission Fluid This version of the story was in one of the Military Vehicle Club newsletters. |
Re: Various penetrating Oils findings
Thanks very much for this info. Like so many on this forum, I have used probably most if not all of the products listed in your post and I do like the results I get from "AeroKroil" made by Kano. I ran out of that recently and can not find it locally so I have been back to trying different brands. I have noticed that some brands attract oxygen and accelerate rusting (want to sell more oil?). Also they have increased the can pressure AND are using the wide area spray pattern (have you noticed that they don't include a small tube any more? Want to sell more oil?). Just some of my observations lately...I am going to mix up an ATF/Acetone batch today and try it out. Thanks again.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
![]() Join Date: Jul 2012
ATF + acetone = kick arse
they could have used my truck, nothing scientific about it but very rusty
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
![]() So Sorry they could use only “Scientific Rusted Bolts” ; it was Government research grant money …… NoT |
I'll have to try the acetone/ATF someday.
I didn't notice Gibbs brand in the test. I'd like to see how it does.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
I like to think of rust as "chemical milling"!!
Very interesting johnnyclack -
I wonder a couple things if you mix your own ATF/acetone; 1) Will the acetone evaporate out of the mixture over time? 2) Can the mixture be safely stored in a glass, or plastic, or metal container?
'65 GMC Suburban 4X4, '71 GMC 4X4 LWB - The Yellow Eyed Monster, '86 C10 Silverado - Oldest Daughter's Pickup, '88 S15 GMC Work Truck, '95 GMC SLE 4X4 - Second Daughter's Truck, '99 K1500 GMC Suburban Road Trip Machine, 2000 C2500 W/T Utility Bed Work Truck, '03 Silverado - Wife's Grocery Getter |
The ATF/acetone mixture, from my experience, should be used withing a few days or maybe a week.
I use this el cheapo oil can from HF. |
I must say that after I read about the ace/atf mixture I gave it a whirl and holey cow does that stuff work good.
I wanted to use it with a spray bottle so I emptyed the last little bit of a cleaner/windex type bottle(the kind that sprays a stream and fan)rinsed it out and mixed up a big batch. I used up a good portion of the bottle within a couple days on tearing down two frames and just about a inch left in the bottle it sat on the bench for a while and the bottle started too melt away ![]() for the price i like buying the acetone and atf it is like haveing a duel purpose products in the shop and only makes sense too me cause it can and will be used either way also there still is a place for the proper rust penetrant/lubricant I dont think you would want too use the atf mixture on parts that are sensitive too the acetone so sometimes a small test spot is a good idea
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Hand Crafted C-10
![]() Join Date: Aug 2006
Sounds like a good "soak" for rusty bolts, tools, etc.
yes it is and it has a aroma thats is kinda nice
#13 | |
Hand Crafted C-10
I’ve always liked making homemade concoctions so this whole thread
intrigued me from the start (thanks Johnny for starting the thread!). Quote:
PET, PVC plastic or metal should work...do not use HDPE. haha...my girlie-side says you are right. Probably wintergreen oil. I'm going to try a home brew that uses contaminated gasoline (unusually hard to dispose of otherwise), lacquer thinner, ATF, turpentine &/or mineral spirits...things I already have. (Plus my own super-secret ingredients) ![]() |
(unusually hard to dispose of otherwise), lacquer thinner, ATF, turpentine &/or mineral spirits...things I already have. (Plus my own super-secret ingredients) ![]() Carefull with the gas, it has a very low flash point ![]() Last edited by ETsC10; 01-23-2013 at 11:32 AM. |
#15 |
Hand Crafted C-10
#16 |
Hand Crafted C-10
