Old 01-16-2013, 03:26 PM   #1
GaryD
GaryD's Avatar
Blow my horn
This is what I have:
Hella Twin Tone Horn without instructions.
Was hoping to replace the horn on my 71 Chev truck
but not sure how to add that little do-hickey in the middle?
My old setup doesn't have one.
Is it a relay of some kind?
Thanks for any help.
GaryD is offline   Reply With Quote
Old 01-16-2013, 07:57 PM   #2
sanford&daughter
sanford&daughter's Avatar
Re: Blow my horn
Yeah it a basic relay
sanford&daughter is offline   Reply With Quote
Old 01-16-2013, 08:02 PM   #3
GaryD
GaryD's Avatar
Re: Blow my horn
I'm guessing the horns connects to the relay (which are connected to the positive side of my battery) and the relay also connects to a ground?
Old 01-16-2013, 08:08 PM   #4
Lattimer
Lattimer's Avatar
Re: Blow my horn
http://www.offroaders.com/info/tech-...ive-wiring.htm
take a look here. They are showing lights, but your horns would go there in the diagram. the wire from the switch would be your stock horn wire.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 01-16-2013, 08:22 PM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Blow my horn
Just thinkin here, If he uses the trucks stock wiring why would he need the relay. The truck has a horn relay already.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-16-2013, 08:45 PM   #6
Lattimer
Lattimer's Avatar
Re: Blow my horn
good point.
Shawn
Old 01-16-2013, 09:03 PM   #7
GaryD
GaryD's Avatar
Re: Blow my horn
I was hoping it would but it didn't. (plug and play)
This new horns have two terminals each coming off of them where as my old horns have only one each.
Didn't think it would matter but I guess it does.
And thanks for the help/diagram guys.
Now it's time for me to get busy...
Old 01-16-2013, 09:06 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Re: Blow my horn
As Ol Blue K20 said, your truck does have one. It is under the dash, on the left side of the steering column. I think the wires to the plug are Red, Green, & Black. Red is power, Black is ground, and Green goes to the horn.
LockDoc
Leon
Old 01-16-2013, 09:07 PM   #9
Ol Blue K20
Re: Blow my horn
Your stock relay is under the dash, the stock horns grounded thru the mounting bracket.
Most likely the Hellas Need to be grounded thus two terminals
Dale
Old 01-16-2013, 09:14 PM   #10
ole dollor
ole dollor's Avatar
Re: Blow my horn
one wire on the horn will need to go to ground one will go to 12 volt source, i think they can be mounted on plastic cars we have today that is why the extra ground on each horn plus then you would know its grounded good...
ole dollor is offline   Reply With Quote
Old 01-16-2013, 09:28 PM   #11
Andy4639
Old member
Andy4639's Avatar
Wink Re: Blow my horn
I would say one terminal is Hot and the other ground. take the singal wire that's in the truck and hook it to one of them and put a jumper on it and see.
No need for the relay in the picture it's already wired into the truck harness.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-16-2013, 10:40 PM   #12
GaryD
GaryD's Avatar
Re: Blow my horn
I'll give it a try this weekend.
Thanks again everyone.
Old 01-22-2013, 11:47 PM   #13
GaryD
GaryD's Avatar
Re: Blow my horn
Honk Honk...the new horn is working fine...
Old 01-23-2013, 02:19 PM   #14
Ol Blue K20
Re: Blow my horn
great, I knew you could "Git er done"
Dale
