Old 02-16-2011, 11:05 AM   #76
67cheby
67cheby
67cheby's Avatar
Re: Lets see pics of wood beds.......
Originally Posted by C10-Driver View Post
I used a spar varnish which has natural UV blockers in it and I believe the product we used had more blockers added so I don't expect any yellowing. I can't remember the brand at the moment but will try to track it down. Mar-K trucks has some great info on the different finishes and what stands up better than others. You should check out their website... It's pretty interesting.
thanks i will do
67cheby is offline   Reply With Quote
Old 02-16-2011, 11:06 AM   #77
67cheby
67cheby
67cheby's Avatar
Originally Posted by AusTx68 View Post
Here's mine..white oak with pecan stain and 4 coats Marine SPAR Varnish.
man the whole inside of your bed looks KILLER
Old 02-16-2011, 02:56 PM   #78
70short
Here is mine
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 02-19-2011, 05:33 PM   #79
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I have White Oak wood from Bruce Horkeys and would like it to look like yours when I'm finished. Did you sand between varnish coats and if so what did you use? Did you apply the varnish with sponge or bristle brushes?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-20-2011, 05:12 PM   #80
AusTx68
AusTx68's Avatar
My wood came from Mar-K but I used Bruce Horkey's Spar varnish kit. It costs $85 and comes with instructions and supplies (varnish, thinner, paper, tack cloths, ect). The kit comes with sponge brushes but I decided to use bristle type. They just felt better. I sanded with sand paper between the first couple coats then switch to green scotchbrite pads for the remaining coats. They lasted longer than the sand paper. I highly suggest getting the kit. The provided instructions are very detailed and remove all the guess work. My pecan stain came from Lowes.
MAKE SURE TO USE A MASK WHEN SANDING. My first day sanding I didn't use one and I had bronchitis for the next 4 days. I didn't make that mistake again.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 02-20-2011, 05:19 PM   #81
Already Gone
Thanks for the info
Old 02-22-2011, 11:59 AM   #82
Steve Hafner
Steve Hafner's Avatar
Here's mine - BEFORE - I'm working on the - AFTER - now !!!
Life is short . . . we only have, right now.
My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526
Steve Hafner is offline   Reply With Quote
Old 02-22-2011, 01:36 PM   #83
RenoKeene
Florida Edition
RenoKeene's Avatar
Check out woodbedandparts.com, I bought the cypress kit. Pre-cut, grooved and drilled, polished s/s rails, bolts everything for about $900 shipped. Havn't finished it yet but as a former Millworker I can tell you this is high quality material, very beautiful. Came well packed and you could tell they take pride in their work. MADE IN AMERICA. In my opinion well worth the $. Check out their site, both domestic and exotic kits.
Reno
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 02-22-2011, 05:52 PM   #84
DustyC10
Reno
BedWoodandParts.com
DustyC10 is offline   Reply With Quote
Old 02-22-2011, 11:40 PM   #85
mrh33916
Project '67 454
mrh33916's Avatar
Great looking beds guys!!!
I've been following this thread for a while now as I'm in the middle of a steel to wood bed conversion on my '67 and I have a question if you don't mind.
Has anyone used a aftermarket wood floor rear cross sill?
How well did it fit?
Do you recommend a certain brand or are they all the same?
Thanks,
67 C-10 SWB Fleetside 454 (current project)
99 Crewcab SWB Dually 454
75 Datsun 280ZZ430
94 Formula 232LS 454
mrh33916 is offline   Reply With Quote
Old 02-23-2011, 12:20 AM   #86
AusTx68
AusTx68's Avatar
Thanks,
My bed was built using Mar-Ks wood conversion kit which includes front panel and all cross sills. I also used their oak wood kit and sandwhiched it between ECE bedsides. Only my tailgate is original GM. The rear sill fit but it wasn't easy. I could'nt get all the holes to line up correctly and their location makes it hard to work with. I know I'm short at least one bolt on each side.
Old 08-19-2011, 11:13 AM   #87
Steve Hafner
And here is the AFTER - the bed has been put onto the truck since this picture was taken.
Red Oak from Bruce Horkey, with two coats of walnut stain, finished with five coats of marine spar varnish and two coats of marine wood wax.
It's almost finished now !!!
Let's see some more WOOD !!!
Old 01-24-2013, 06:11 AM   #88
Expat_dude
Expat_dude's Avatar
Nice looking beds! Any others?
1970 Chevy swb, project UGHH!
1987 Grand National
http://s168.photobucket.com/albums/u.../1970%20Chevy/
Expat_dude is offline   Reply With Quote
Old 01-24-2013, 08:01 AM   #89
mrh33916
Project '67 454
mrh33916's Avatar
Here's mine,
White Oak from Horkeys, custom stain, marine varnish
75 Datsun 280ZZ430
Old 01-24-2013, 10:48 AM   #90
50bomb
50bomb's Avatar
Mine aint nice like all yours. My truck is a 67 but the bed is off a 68 chevy. THis is when I first put it on. Looks like the Original wood from factory and still in decent shape for me. I will someday replace it. I got this bed for "FREE" from board member Rmanson. I been wanting to convert to wood floor since I checked out this truck FOR sale over 2 years ago. Something about these floors that just gets me going.
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 01-24-2013, 11:12 AM   #91
Fitz
Originally Posted by trev1 View Post
Were buildin a 69 longbed and thinkin of puting a wood bed into it. Lets see some pics of your wood bed. My son is not sure if he wants one in the truck. Lets show him how nice they can look.......I want one................
Purpleheart with 4 coats of Cetol Marine Varnish.
Fitz is offline   Reply With Quote
Old 01-24-2013, 11:31 AM   #92
71K20chevy
71K20chevy's Avatar
Original wood
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 01-24-2013, 01:27 PM   #93
ole dollor
ole dollor's Avatar
this is what i have...
ole dollor is offline   Reply With Quote
Old 01-24-2013, 01:29 PM   #94
joesgreen67
joesgreen67's Avatar
Maybe I'm the only on here ....BUT...I used 7 coats of Helmsman spar urethane and after 3 short months it started to gray out.
Looked killer at first, but now it looks terrible IMO.
I tried refinishing but was never really satisfied with the results of the refinish.
I bought new wood (not installed yet) but Im seriuosly considering just buying a metal floor box and getting a spray in bed liner. I rarely use my truck to haul anything. The upkeep of the bed wood was just more than I expected.
joesgreen67 is offline   Reply With Quote
Old 01-24-2013, 02:11 PM   #95
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Here is one I did for a customer of mine. I don't loke gas fillers in the middle of the bed, but in this case I didn't have choice because of the gas tank he used. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-25-2013, 08:58 AM   #96
WadmalawJoe
WadmalawJoe's Avatar
What a bummer, did you apply any primer/sealer stuff at first or just straight up spar urethane on it?
Check out Mar-K's test,
http://www.mar-k.com/final_summary.aspx
it's some good info
Toys/projects
Many toys, not enough time to play!
My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!!
WadmalawJoe is offline   Reply With Quote
Old 01-25-2013, 10:35 AM   #97
joesgreen67
it's some good info
WOW! That is some good info!
I used straight up helmsman spar urethane. With all the coats and attention to detail I gave it, I expected better results than what I got.
I've considered using composite deck material instead of wood all together. Ive seen a posting here & there about guys using it on their trucks but perhaps its time to revisit it.
Old 01-25-2013, 01:58 PM   #98
BugzC10
BugzC10's Avatar
Oak + polished Stainless. MAR-K kit
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 01-27-2013, 02:02 PM   #99
panhead59
Nice beds. Just remember, if someone is thinking about a wood bed, that they aren't going to stay "nice" if u use them. I put new tires, to get mounted, in the back of my new wood bed and they caused enough "mess" that nothing and I mean nothing will ever go into that bed again. But I'm going to sell it so--- lesson learned for me.
panhead59 is offline   Reply With Quote
Old 01-27-2013, 03:06 PM   #100
BugzC10
BugzC10's Avatar
That's the issue I saw when replacing the bed....I did want to use it. How to show it off and use it lightly?. Besides shooting 4 coats of Helsman polyurethane I also have a clear plyable plastic 1/8" thick sheet laid over the bed. So far I've only carried light cardboard boxes. Still looks good, but I don't expect it to stay perfect.
