#26 | |
Who Me?
Re: fuel tank regret
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#27 |
Can anyone supply me with a pic of the cab floor with the gas tank removed. The PO of my truck cut out the tank supports at the bottom. I need to see what I am missing so I can purchase some new used mounts to put back into my cab.
Yes, I have decided to put my tank back into the cab. oh, and thanks for all of your great thoughts and suggestions.
past trucks: 1980 C-10 Silverado SWB 1961 C-10 custom cab LWB 1966 C-10 custom cab LWB |
#28 |
![]() Join Date: Sep 2012
i will try and get you a pic tomorrow unless someone else gets one for you i got a cab that i just took off and am parting out since the the cab supports rusted out bad and i bought another truck i can cut out the mounts and you can buy them if you like they are in good shape just pm me if you are interested in them thanks
#29 | |
#30 |
#31 |
well I cant get you pics just walked out to look at it and I must have cut the tank mounts out years ago when i removed the tank so I cant get you pictures sorry
#32 |
"Where were you in '62?"
![]() Join Date: Jul 2004
Hey bonehead,
If you want to go back to original I have my Old Tank For Sale. "1962 Chevy C-10 Stepside Stock Gas Tank" http://67-72chevytrucks.com/vboard/s...d.php?t=355704 ![]() "1962 Chevy C-10 Stepside Parts for Sale" & miscellaneous stuff! http://67-72chevytrucks.com/vboard/s...d.php?t=337099
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#33 |
![]() Join Date: Oct 2006
so what options do the 60-62 guys have to mount there tanks under the bed?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#34 |
so what options ( that dosnt cost an arm and a leg )do the 60-62 guys have to mount there tanks under the bed?
#35 |
most of the takes that fit in a 63-66 will fit in a 60-62 you will just have to a little more work and be creative when strapping it in.
#36 |
bonehead,
Do you still need pictures? I am going the "under bed" route and have taken my original tank out. It had about half a tank of fuel left in it. I tried to pour it out but there was so much rust and scale that the fuel almost dripped out instead of poured out. I'm not sure what it would take as far as labor and money to fix. I'm willing to "pay it forward" and give it to you if you'd like it. Not trying to highjack your thread, but this seems like a good place to ask this question. I'm installing a 5.3 and will need a tank capable of supplying fuel to an EFI engine. Will the rear mount aftermarket tank the LMC sells (http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=35) work? It says it has fittings for return and/or vapor lines. |
#37 |
Thanks, but I found the picture I was looking for. I have the replacement tank mounts coming, thanks to Mack B, to replace my hacked mounts (no thanks to the PO).
I would only trade for a nice clean (currently in use) tank or I will buy a new one.
#38 |
I wasn't looking to trade, I was just going to give it to you if you felt the time and effort would be worth it.
#39 |
I have all the parts you need to bring it back to stock. Gas tank, straps filler neck, with new rubber coupling, including c-clamps, original gas lines, rubber pads and stock gas cap. The biggest thing you need is the welding in gas tank stand which are behind the seat. Is your hacked up or is is left alone? Not only are they the gas tank mounts (and for the staps), they are body supports for the back and floor of the cab. I don't have those. I hacked mine up. I have it listed in SF craigslist, cheap!
#40 |
Re: fuel tank regret *update*
Ok guys here is an update on my c-10 cab tank retrofit.
I welded the tanks mounts back into my cab. Rather than remove the whole neutered bracket from the cab (there are a lot of spot welds), I did a splice about 1/2 inch behind the bolts. This way the bolts held the new stub pieces in place while I welded them fully. Now they are rock solid and ready to be painted. I also reopened the filler on the side of the cab. I did this by first using a hole-saw to remove most of the metal patch, than trimming as close as I could to the edge with tin snips. Then I ground the rest back to the original folded edge using a small round grinding stone in my drill. I just snuck up on the edge and it come out great. the rubber and filler neck fit perfect. As soon as I get the mounting brackets painted I will start installing the tank. When I get everything hooked up but the fuel line I will then remove the rear tank and finish hooking up the fuel supply to the new/old cab tank. I will update as things progress for those who might have an interest in this retrofit.
