Re: Cab corner trim ?
Shouldn't be hard to get the hole right on the new cab corners. First take some thinline tape (regular masking tape will work) and tape lines at the top and bottom edges of the trim from the door to the bedside. Ten put a line halfway between the pieces of tape. That will give you a centerline. I'm presuming that they have a clip that mounts behind the trim and not external screws. Figure how far the clip is from the front of the trim, add whatever stback from the edge of the panel that is needed and place your mark on your centerline. Repeat for the remaining holes that are required. The only difference with the rest of the holes are that you just measure from center of clip to center of the next clip. Hope I described this in a way that is easily understood.
