conversion from 5 on 5 to 5 on 4.75
Does anybody know of a front rotor conversion for my truck to go from a 5 on 5 bolt pattern to a 5 on 4.75 bolt pattern
Re: conversion from 5 on 5 to 5 on 4.75
![]() Had these on my Jeep Cherokee for a while, albeit they were just spacers and never had a bit of a problem with em. They should work great!
Jason TEAM C10 HOT ROD POWER TOUR
689 Short Step 68 Step Trucks Sold: 70 GMC, 72 K5 Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins |
thanks for the info. I was hoping to go with just rotors, and stay away from adapters. I'll put the info in my data base.
67-72 parts collector,…
![]() Join Date: Nov 2002
CPP and McGaughy's both sell a big brake kit that has 5x4.75 rotors.
This a picture of a jig for redrilling hubs and axles. You can do it with a good drill press however the jig is best made at the machine shop. I have the numbers if its what your after.....ruggles[IMG]
#6 | |
![]() Join Date: Mar 2011
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
Check the numbers before you use it. I haven't used this pattern yet.On some axles or hubs you may have to weld a hole or two. probably not in the case.....ruggles[IMG]
![]() Last edited by ruggles; 01-26-2013 at 12:23 AM. Reason: info |
#8 | |
![]() Quote:
![]() edit - just saw you joined a year ago ![]() ![]()
I've done it with all stock components , let me know if you want more info on it. What year is your truck?
performance online has a 5 on 4-3/4 rotor...pt#5100
I'm interested, did you use all off the self stocks parts??
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
Those are the rotors they use in their "drum brake spindle" conversion.
I would like to thank everybody for the great help. I have taken all the info and stored in my data base and will be checking it all out. Thanks to a great following. BOBUILT
