![]() Join Date: May 2008
wtb carier bearing bracket.
lost my bracket for my carier bearing...i think there is three styles. so if any one has any post pics..my truck is a long bed leaf truck...if that helps.i was going to do a one piece but now i have changed the plan....any help...jeemy
![]() Join Date: Apr 2007
Re: wtb carier bearing bracket.
Hi Jeremy, 71 C20 leaf sprung. Sharpie
mine bolted to the bed side of the cross member...i saw another one in a junk yard the other day but its the kind of yard where only there guys pull parts for ya...spendy. if anyone else has pics that would be cool. im sure this style might work but i think the driveline lenths would be different.
does this help
nickle and dime |
nope neither of those...anyone else help?????
![]() Join Date: Oct 2009
This one is probably not correct because it is off of a 68 coil spring truck but maybe it will show you something. It would use the carrier bearing like the one with 2 bolts in a line posted buy ROYO. TTT for you anyway. Good luck and happy searching.
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
i had no idea they had so many different brackets...thanks for ypur time in posting the pics.someones got to have the same style i had though...i think we are almost out of options.
What engine did your truck come with? BB is different than SB
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 03-29-2010 at 02:15 PM. |
thats the one...my truck is sb.350. thanks for the pic.now i just need to find one.
![]() Join Date: Jun 2005
Does it attach to the frame crossmember with 2 bolts or 4 bolts. I have both $25 for 2 bolt and $35 for 4 bolt plus shipping. LMK, I can send pics. Thanks, Dan
cool post some pics of what you have.i dont remember if it was 2 or 4.ill get some pics up of my available mounting holes.
The 2 hole is the black one and will need to use a bolt and nut to attach, as the threaded holes were partially drilled out. A grade 8 bolt and nut will be better than factory. the 4 hole has the old bolts in it. LMK
Here a original 2 bolt bearing carrier from 70 C20 with newer bearing, currently being used on a 68 C10 SWB.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 03-30-2010 at 03:15 PM. |
pretty sure its the four bolt...ill send ya a pm shortly..jeremy
#15 |
#16 |
![]() Join Date: Mar 2010
Here are some pics of bracket willing to sell. Asking 25.00 shipped to you. Thanks
#17 |
Hi,
I want to purchase the 2 brackets, but want to make sure we are talking about the same parts. I tried to attach a picture of exactly what I need but could not?? I am somewhat new to the site.... In your picture it is the 2 piece driveshaft on the right. The 2 triangle shaped brackets are bolted together by 3 bolts with the carrier bearing and rubber bushing sandwiched inside. These 2 support brackets bolt to a bracket on the center frame support, different than the ones in the pictures. I have the attaching bracket and one of the two triangle shaped brackets that the driveshaft goes through and holds the bearing. I need the 2 triangle shaped brackets. Thanks, Dave |
