Old 01-27-2013, 09:24 PM   #1
Yellow72C10
HELP! First truck, need to be back on the road
Hey, my name is spencer and I've got a 72 chevy half ton, that's a short bed, stepside. It was my grandfathers and he bought it new in 72, so it's a family truck. He passed away the year I was born, and I'm gunna fix it up so I can drive it when I get my license. But I don't know where to start! It has the factory original 350 with a automatic in it. We had it runnin last summer but these winters are hard on it lol. Please, tell me where you started and any tips would be greatly appreciated! Thanks!! I'll try and put up pictures soon
Yellow72C10 is offline   Reply With Quote
Old 01-27-2013, 09:39 PM   #2
daves72C10D
daves72C10D's Avatar
Re: HELP! First truck, need to be back on the road
Welcome. You need air, fuel and spark. Check for those. If you do not have either then you know where to start. Got any picts? Good luck.
1972 Custom 10 Deluxe- original paint, interior- 72k miles
http://www.cardomain.com/ride/2466316
Cheap, Fast or Good. Pick any two.
1990 Eagle Talon AWD
1991.5 W250 CTD
1992 Cushman Truckster- Haulster
daves72C10D is offline   Reply With Quote
Old 01-27-2013, 09:43 PM   #3
Yellow72C10
Yessir, I know it'll crank. A little ether in the carb and it does but she runs rich.
Old 01-27-2013, 09:47 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
You may also want to put some fresh gas in the tank. If the gas in the tank is over a year old, it may become tarnished and not burn well. May save you some grief.
TBONE1964 is offline   Reply With Quote
Old 01-27-2013, 09:54 PM   #5
Yellow72C10
What about seafoam, does that help any?
Old 01-27-2013, 10:12 PM   #6
Aaron Burkemper
Aaron Burkemper's Avatar
x2 on making sure you have fresh gas. Running rich may mean dried gaskets, sunken float, or bad needle and seat.
1971 C20 "Shreck"
1980 C30 dump bed "Ratchett"
Aaron Burkemper is offline   Reply With Quote
Old 01-27-2013, 10:20 PM   #7
Yellow72C10
I appreciate the quick responses, so is the carb the first place to start? I know that the gas is only a few months old, so I think it's alright for now
Old 01-27-2013, 10:21 PM   #8
Yellow72C10
Oh and I know it has a quadrajet 4 barrel on it
Old 01-27-2013, 10:46 PM   #9
Sklptrljay
Sklptrljay's Avatar
Heres's an inexpensive but common problem when a motor sits for a while. Try removing the fuel filter and turn the engine over for a few seconds to clear any junk, replace with a new filter and give it a shot. Also, the q-jets have an internal filter in the carb that can get gummed up.
Sklptrljay is offline   Reply With Quote
Old 01-27-2013, 10:57 PM   #10
Scott>72-GMC
Scott>72-GMC's Avatar
Giving the system a good clean wood be a good start filters and such new spark plugs oil change never hurt if u plan on rebuilding the engine the oil change might wait
Scott>72-GMC is offline   Reply With Quote
Old 01-27-2013, 11:07 PM   #11
Yellow72C10
How do I tell what size plugs it needs? Also what is a qjet? Sorry for all the questions, a I'd appreciate the help!
Old 01-27-2013, 11:10 PM   #12
71K20chevy
71K20chevy's Avatar
Qjet=Quadrajet
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 01-27-2013, 11:11 PM   #13
Scott>72-GMC
Easiest I've done is either take one out with me to the parts store or know what engine u have and tell them there are numbers on the plugs typically
Old 01-27-2013, 11:12 PM   #14
Sklptrljay
Sklptrljay's Avatar
Q-jet is a quadrajet. If you look where the fuel line goes into the carb, there should be an internal filter inside the carb.
Old 01-27-2013, 11:12 PM   #15
sameyrasmea72
sameyrasmea72's Avatar
It works great!!!!!!!!! pour some in the tank and fill up the carb with it. let it set in carb over night.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 01-27-2013, 11:14 PM   #16
Sklptrljay
Sklptrljay's Avatar
Or try and spray some starter fluid in the carb and crank it over, sometimes if you just get things moving and running it clears out all the junk.
Old 01-27-2013, 11:25 PM   #17
Yellow72C10
The fella at my parts place recommended seafoam. I appreciate the help a,d tips, and I'll try it all tomorrow. Thanks!
Old 01-27-2013, 11:29 PM   #18
Yellow72C10
Can i just tell them I've got a 350 for the plugs? Or do I need to take one them up there?
Old 01-27-2013, 11:37 PM   #19
Scott>72-GMC
If its the original engine u can just tell them year size motor and everything. I'm no expert I'm sure others will chime in might even know the size plug on top of there head but I would just take one in only takes a min to take out
Old 01-27-2013, 11:45 PM   #20
Yellow72C10
How are plug sizes measured?
Old 01-30-2013, 12:56 AM   #21
Yellow72C10
Old 01-30-2013, 12:56 AM   #22
Yellow72C10
This is it lol. I'll take some better pictures soon
Old 01-30-2013, 01:09 AM   #23
Scott>72-GMC
Looks sweet nice front bumper
Old 01-30-2013, 01:17 AM   #24
Yellow72C10
Thanks. My grandpa welded that bumper together and put a 8k pound warn winch on it.
Old 01-30-2013, 01:29 AM   #25
BlackedOut67shorty
BlackedOut67shorty's Avatar
Diggin the bumper. Also maybe if the gas is possibly bad you could check by having a can of good gas and bypass the fuel line from the tank putting it just before the fuel pump. If it still doesnt run then use a spark tester to see if you are producing spark. Hopefully this helps out.
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2011 subaru impreza sport
2001 s10 blazer 4.3
1992 chevy caprice wagon
BlackedOut67shorty is offline   Reply With Quote
350, 4wd, automatic, restore, stepside
