Old 01-27-2013, 02:05 PM   #1
Grimm76
pulling tranny got questions...
I am going to replace the 250 in old Grimm, it has a granny-low 4-speed that looks like it has a leak at the back. I want to pull it out as well as the engine.
From looking at the Haynes manual, it looks like there are 4 large bolts at the rear end of the bellhousing that need to come out and then the trans gets moved back and down to remove. Question is: Does the bell housing assembly come out at the same time the engine does? I am more familiar with auto trannys than I am this manual. Not exactly sure how to proceed... comments and suggestions are appreciated!
thanks in advance.
Grimm76 is offline   Reply With Quote
Old 01-27-2013, 02:09 PM   #2
krazy_texan
krazy_texan's Avatar
Re: pulling tranny got questions...
Yes the gear box will unbolt from the clutch and the bell housing. The bell housing will come out with the engine
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 01-27-2013, 02:22 PM   #3
Redcap
The above is doing it the hard way. Much easier to unbutton the bellhousing from the back of the motor to pull it.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 01-27-2013, 02:59 PM   #4
86c20
86c20's Avatar
I have done motor swaps where I left the trans in with the bell and pulled the motor. Just taje the rad out firs
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 01-27-2013, 04:44 PM   #5
krazy_texan
Well not saying I would necisarilly do it that way but it answered his quistion lol it has been a while since I dropped a transmission
Krazy Texan
1990 v1500 suburban
Old 01-27-2013, 09:40 PM   #6
Grimm76
Thanks for the input. I have a tranny jack to put underneath, and then can undo the bellhousing bolts. I was just figuring to pull the trans out prior to the motor so I can dink with the leaky seal on the back of the trans.
I'll probably be back with another q or 2
thx
