Front spring shackle help
I purchased this rebuild kit for my 57 front end. http://www.classicperform.com/Store/.../5559SHK-F.htm
I am a little concerned because it doesn't look like the old stuff I removed. In particular, the threaded pins. My old stuff had nuts on the end of the threaded pins. The new pins don't extend past the shackle plates. Am I to assume that the center (long carriage bolt) bolt keeps the shackle plates squeezed together and that's it? This kit didn't come with any instructions so I got nothing to reference. Also, is anyone familiar with torque values for the hardware on the front axle? Didn't find anything in my assembly manual except for the ubolt nuts. Thanks in advance.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
Re: Front spring shackle help
you are correct, the long bolt holds it together
my rears are the same, it doesn't look very stout, but it works
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Your old stuff may have been replacement pins from some vendor who put the nuts on them as part of their design. The ones you have appear to be the factory style but LMC does show a different second series shackle that doesn't appear to use the threaded pins.
http://www.lmctruck.com/icatalog/ca/full.aspx?Page=91
Any idea what the torque value would be on this center bolt?
