Old 01-28-2013, 11:52 PM   #1
lil_sahara450r
Headers for a bagged 66.... (I searched... I promise!!!!)
Ok, before I get flamed for this, yes, I have searched the board high and low.
Here we go! I have a bagged 66 SWB with a small block. I'm not dragging the ground with this truck. Its bagged with drop spindles and c-notch'ed, with about an inch or two clearance from the bottom of the front crossmember to the concrete. I would like to keep the exhaust tucked above the bottoms of the frame rails if I can. I also have a TH400 in the truck, so no linkage interference "should" exist (correct me if I'm wrong).
Does anybody have a part number for some headers and pics of what I am searching for?
Many thanks to y'all!!!
lil_sahara450r is offline   Reply With Quote
Old 01-29-2013, 12:02 AM   #2
19GMC66
19GMC66's Avatar
Re: Headers for a bagged 66.... (I searched... I promise!!!!)
I'm running a dropmember with bags and used the patriot clipster ceramic headers mid length for a Chevy Smallblock.. Think I got them from summit racing good quality fit well with no interference
19GMC66 is offline   Reply With Quote
Old 01-29-2013, 12:13 AM   #3
lil_sahara450r
http://www.summitracing.com/parts/pte-h8021-1
These?? Those are pretty attractive, especially at that price! Do you have any pictures?
Old 01-29-2013, 12:16 AM   #4
19GMC66
19GMC66's Avatar
Yep those are it.. Yeah the price is nice and the headers are quality too come with everything you need to install them also.. Not sure if I have any close up pics for you
Old 01-29-2013, 12:21 AM   #5
19GMC66
19GMC66's Avatar
Drivers side
Old 01-29-2013, 12:23 AM   #6
19GMC66
19GMC66's Avatar
Passenger side.. The headers come down at different angles for each side but no fitment issues and my truck lays frame in the front
Old 01-29-2013, 12:26 AM   #7
lil_sahara450r
Wow! Those look GREAT!!! I think those are the ones! they seal up pretty good for ya?
Old 01-29-2013, 12:27 AM   #8
19GMC66
19GMC66's Avatar
Yes sir they have been great so far
Old 01-29-2013, 12:39 AM   #9
lil_sahara450r
Great! Can't say enough about this board! Post a question and get an answer in ten minutes with pictures!
Old 03-22-2013, 10:31 PM   #10
lenguini
lenguini's Avatar
What brand motor perch are you using,I have had concerns with this brand header using a factory perch.
Thanks in advance
Ed
Always a place in my heart for old Chevy trucks:
My build thread-project truck dream 65"
http://67-72chevytrucks.com/vboard/s...d.php?t=510863
lenguini is offline   Reply With Quote
Old 03-22-2013, 11:27 PM   #11
19GMC66
19GMC66's Avatar
I am using the the ones that came with porterbuilts dropmember..
Old 03-23-2013, 12:00 AM   #12
lenguini
lenguini's Avatar
In your opinion do you see any problems at eye shot using a stock motor mount with your headers ?
Thanks,
Ed
Old 03-23-2013, 12:03 AM   #13
19GMC66
19GMC66's Avatar
No I wouldn't think so seems like plenty of room even with stock mounts... Not sure if anyone has tried them
Old 03-23-2013, 12:48 AM   #14
lenguini
lenguini's Avatar
Thanks for the info.I have a set lined up for tom aft.
Cheers,
Ed.
Old 03-23-2013, 07:51 PM   #15
creep
Registered Loser
creep's Avatar
I'm using the same headers on my truck, good clearance with the framerails and plenty of room to run a steering shaft with 2 knuckles.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 03-23-2013, 09:22 PM   #16
lenguini
lenguini's Avatar
Thanks for the input.Just bought the set today but I was told by the seller the front pipe both sides hit the stock engine perch's....., What are you running for engine mounts ?Cant see em in your pics.
Hope I wont need different ones.
Cheers,
Ed
Old 03-24-2013, 09:33 PM   #17
creep
Registered Loser
creep's Avatar
I have an aftermarket crossmember with its own motormounts. I can see where the stock mounts might interfere. Never thought about that.
