Old 01-29-2013, 09:27 AM   #1
Jackjohn
Dash lites
Does anyone know if there are replacement bulbs for our dashes, that are brighter. Mines a 66.
Thanks,
John
Jackjohn is offline   Reply With Quote
Old 01-29-2013, 11:00 AM   #2
Lugnutz65
Lugnutz65's Avatar
Re: Dash lites
Thanks,
John
Jackjohn,
I'm restoring my 65 instrument cluster. I read other forums too and found a thread about LED bulbs. I have not tried them yet, but they might be brighter and less likely to burn out.
The website is www.superbrightleds.com.
It's something to think about. The LED bulb doesn't dim, so keep that in mind.
Keep in touch and I'll tell you how well they work (if I switch to LED).
Another thought that came to mind last night as I cleaned my 65 cluster - the cardboard tubes could be lined with a reflective material like mylar so that more light would reflect from inside the tube. Just another thought.
Jay
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 01-29-2013, 11:13 AM   #3
Jackjohn
Re: Dash lites
I would really like a standard bulb,just brighter, but thank for your help.
John
Old 01-29-2013, 05:50 PM   #4
ray_mcavoy
Re: Dash lites
Hi John,
The 66 owner's manual lists the stock instrument cluster illumination bulbs as #1895's. They're rated at 2cp (candlepower) at 14 volts.
You might want to try some #1816 bulbs. They have the same miniature bayonet base but are rated at 3cp at 13 volts. They should be noticeably brighter but will have a slightly shorter lifespan (about 1000 hours as compared to 1500 hours of the 1895 bulbs according to the Sylvania website).
Also note that some locations (like the high beam indicator) used an even dimmer #1445 (1cp) bulb that also has the same base. You'll probably want to stay with that bulb there so you don't end up with an overly bright indicator.
Finally, it might not be a bad idea to measure the voltage on the gray wire that feeds the instrument panel illumination lights just to make sure the rheostat in the headlight switch is supplying full voltage when the knob is turned up for maximum brightness. You can gain easy access to this circuit on the "LPS" terminal on the fusebox (near the upper right side if I remember correctly).
ray_mcavoy is offline   Reply With Quote
Old 01-29-2013, 06:06 PM   #5
64fleetside
Re: Dash lites
Make sure your inst panel is well grounded, also. Sometimes paint etc can hinder the grounding.
64fleetside is offline   Reply With Quote
