Old 01-29-2013, 08:20 PM   #1
Maroon_Madness
Maroon_Madness's Avatar
Extended Brake Lines
I Have a 85 K5 blazer with 9-10" of suspension lift but I need new brake lines that go from the frame to caliper. Does anyone have any experience with extended brake lines or know where to get decent ones from? Any help is Appreciated
1990 K1500 RCSB Sport Daily Driver
1994 K1500 Blazer 350 4L60E np241 4X4 3.42's
Maroon_Madness is offline   Reply With Quote
Old 01-29-2013, 09:17 PM   #2
xole
xole's Avatar
Re: Extended Brake Lines
Mine did not have as much lift and I used Russell Performance. The packaged kits only lists stock and then 4" lift for that year but they have pre-assembled universal ones.
They were purchased by Edelbrock so you can get them from just about any online retailer or retail chain. I purchased mine through Summit.
'86 Chevy K10 SWB Custom Deluxe 4x4
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
xole is offline   Reply With Quote
Old 01-29-2013, 09:40 PM   #3
88Jimmy4x4
88Jimmy4x4's Avatar
I buy all my lift components from these guys
http://offroaddesign.com/catalog/braidedbrakelines.htm
We've built layer upon layer of strength and protection into our all new, exclusive top-quality, DOT-approved extended braided stainless steel brakeline kits!
They have a tough teflon tube at the core, but the next layer is a Kevlar braid, then an extra protection layer, the stainless braid, and then the protective outer vinyl cover. The fittings are all one piece crimp fittings and lines are DOT spec!
if that doesnt suit you then try superlift or skyjacker
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 01-30-2013, 02:15 PM   #4
Maroon_Madness
I've been thinking about the ORD lines and just do it the right way the first time instead of jerry rigging an extended one and piecing it together. Its expensive for brake lines but at least with ORD you get a rear with it too
Old 01-30-2013, 06:03 PM   #5
88Jimmy4x4
88Jimmy4x4's Avatar
It's not cheap at $127 but like you say that's for all three lines so not too bad.
1991 GMC Jimmy 4x4
Old 01-30-2013, 07:33 PM   #6
85sierraclassic
85sierraclassic's Avatar
Take your pick kinda pricey on some but what isn't now days
http://www.rockymountainsusp.com/W_brakes_GM.htm
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Old 03-14-2014, 07:54 PM   #7
tommartin
tommartin's Avatar
I stopped by a hose shop today, and they guy had some extensions. I'm looking for some extension or longer lines for the front on my 79 k10.
Would it be a bad idea to use a universal extension instead of replacing the whole line?
tommartin is offline   Reply With Quote
Old 03-14-2014, 08:30 PM   #8
willett
Another Day, Another Dollar
willett's Avatar
Go to an industrial hose shop and they can make you nice ones out of stainless braid
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 03-15-2014, 07:43 PM   #9
Krwright
Go to your local parts store and ask for a set for a 94 c 2500 7200gvwr. They are 6" longer than stock square hoses. The ones for a 8600gvwr are only 2" longer. Cut the bracket off and bend the hard line a little. I picked up a pair from advanced for 18$. I use these often but haven't tried them for a 10" lift.
i do my burn outs in 4wd
Krwright is offline   Reply With Quote
