Old 01-30-2013, 04:01 PM   #1
71K20chevy
71K20chevy's Avatar
Tilt wiring adapter
I might be buying the repro tilt column from Brothers, but from what I understand, you need a wiring adapter. Can't find any other info. I really don't want to spend $20 for something I don't need, so do I need it?
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 01-30-2013, 04:03 PM   #2
bigblock68
bigblock68's Avatar
Re: Tilt wiring adapter
gm part#1894851
bigblock68 is offline   Reply With Quote
Old 01-30-2013, 05:01 PM   #3
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Do not mean to hijack this thread but i had a stock 3 on the tree column that had the adapter when i pulled it from the truck and when i put the tilt wheel (automatic) i did not need the adaptor. the half moon truck harness pluged right into the column harness. Am i missing something.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 01-30-2013, 05:11 PM   #4
bigblock68
bigblock68's Avatar
depends on what switch came in your column...some may need an adapter
Old 01-30-2013, 06:00 PM   #5
71K20chevy
71K20chevy's Avatar
This is the new reproduction from Brothers, from the pics I can't tell which connector it has. Thanks for the help, sounds like I'll have to get the part.
71 K20
64 GMC mud truck
Old 01-30-2013, 07:10 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
Your stock truck harness is the half round one. A lot of aftermarket turn signal switches and columns come with a flat connector. You need to adapter to interface the two. You might could re pin the flat pins into a used half round connector off an old column, but I have never tried it.
WIDESIDE72 is offline   Reply With Quote
