What exhaust manifold would I get I have a 69 with a 1976 305 in it. I just swapped in new header gaskets and it was a pain. I noticed that my sparkplug on drivers side is against them. If I wanna change plugs gonna have to pull header. How stupid. It also depends on cost. Might have to keep what I have for awhile? Just thinking.
Posted via Mobile Device |
![]() Join Date: Dec 2012
Re: i saw the post about headers and i'm sick of mine
My 72 has a 305 from an '86 and it has the ram horn manifolds. Probably find a used set pretty cheap at a junkyard.
1972 C10 CST LWB |
Is there any difference in a 72 or 86 exhuast manifolds? Are they cubic inch specific or will ones off a 350 or any small block Chevy work?
These were the 72 manifolds off a 350 and they bolt up just fine.
1972 C10 CST LWB |
![]() Join Date: Jan 2001
One of the many reason's I'm getting rid of my headers is that I have to crawl underneath and use an open-end wrench to change my number 2 plug.
#6 | |
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
![]() Join Date: Apr 2008
They make spark plugs that are shorter than normal for this exact reason. Not sure what brand the are but they showed them on horsepower tv last week.
I have a set of headmens on my truck and then I stuck in a set of short plugs (Accels) so I have more clearance on the plug wires. But even before that the plugs were not to hard to change out.
Now my Nova is right tight thats for sure. Posted via Mobile Device |
I've used the shorty plugs from Accel, but the header tube is still in front of it; I can't get a socket on it.
#10 | |
laying low
![]() Join Date: Mar 2001
As Boog said the center dump (strait down) are for the 4X4's, and the angled back are for the 2wd's. The later style are a "log" type. I diddn't know they would interfere with the frame. You wouldn't want those over the ram horns anyway. The ram horns will bolt up to at least all 86 and prior SBC heads.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). Last edited by airdale94; 01-30-2013 at 11:41 PM. Reason: add |
Sanderson has cast headers that offer the best of both worlds. Plus you can often find them cheap used.
