Old 01-28-2013, 09:18 PM   #1
clemsonteg
Porterbuilt Stage 1 drop
What kind of drop can be obtained with the Porterbuilt stage 1 kit front and rear at ride height? How much drop can be obtained in the front with airbags while still being able to get a proper alignment?
clemsonteg is offline   Reply With Quote
Old 01-29-2013, 01:24 AM   #2
Pro Performance
Pro Performance's Avatar
Re: Porterbuilt Stage 1 drop
This truck has the Stage1 front & Stage 2 basic in the rear, which has a c-notch and allows it to be a tad lower in the rear. The Stage 1 rear will be about appx. 1" or so higher without the c-notch. The Stage 1 will rest the axle almost on the frame.
Your ride height would be similar to a static dropped truck, and you will want to align the truck at ride height. The truck will align without any issues. Truck below uses drop spindles, which is ideal when bagging a truck.
Pro1 Air Ride Kit
- Travis
Pro Performance is offline   Reply With Quote
Old 01-29-2013, 12:30 PM   #3
clemsonteg
Thanks for the info. For the rear I'm not too concerned. For the front what I would like to know is how much can I lower with only airbags and still get a proper alignment. For normal springs it seems like around 3 inches is the max, is it the same for bags? I know it could go lower aired out but I am thinking more along the lines of when I am driving around.
Old 01-29-2013, 12:34 PM   #4
Pro Performance
It will be the same for the bags, when used with stock arms and front suspension. Your suspension (arms, ball joints, tie rods) are in the same position whether an air bag or air spring is in there.
Old 01-29-2013, 12:52 PM   #5
shawno72
C/10 junkie
shawno72's Avatar
nICE
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-30-2013, 10:52 PM   #6
Hart_Rod
Hart_Rod's Avatar
One or two piece drive shaft???
Hart_Rod is offline   Reply With Quote
Old 01-31-2013, 02:07 AM   #7
PBFAB.COM
PBFAB.COM's Avatar
Pretty sure it's a one piece. I can confirm on Monday (the owner stocks us with all our shop supplies).
He has a build thread on here, but don't remember his user name.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
