Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-23-2013, 12:39 PM   #126
thor
thor's Avatar
Re: How To: Ruin a Perfectly Good K/5
Originally Posted by gringoloco View Post
Thanks! It is a beautiful piece of driveway art right now, as I'm pretty sure it ate the camshaft
So, no progress here, but check this thread to watch us ruin a perfectly good Suburban using a full Ridetech and Accuair system
http://67-72chevytrucks.com/vboard/s...d.php?t=543924
Sorry to hear about the camshaft man! But, it's now an excuse to upgrade.
Also like the Sub build. Nice!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 01-23-2013, 03:44 PM   #127
Jon01
Jon01's Avatar
Bummer to hear about the cam - If you stick another flat tappet in it I'd suggest getting a zinc additive from Summit or wherever and adding it to the oil at every change.
Modern oil is short on zinc content which causes these kinds of issues with flat tappet stuff.
Edit - another thing to do is avoid idling for extended periods. Low engine speeds reduce the rate of rotation of the lifters.
Jon01 is offline   Reply With Quote
Old 01-23-2013, 09:21 PM   #128
gringoloco
A guy with a truck
gringoloco's Avatar
Not certain on the cam, haven't had a chance to dig in and investigate. I do know that it was getting ZERO oil to the rockers on both banks, but holding 60psi. I haven't been able to find anything that would cause this. It was making plenty of racket, too...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-29-2013, 01:12 PM   #129
69gmcc10
69gmcc10's Avatar
I dont know why you are even worrying about it, just drop in the ls you have and problem solved!
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 01-29-2013, 02:05 PM   #130
gringoloco
A guy with a truck
gringoloco's Avatar
If it were only that easy--I just don't have time to fool with it. I ordered a GM crate for it today along with a new HEI. I'll slap on a rebuilt carb and call it good. Normally, this would be an opportunity for an upgrade, but I have other more pressing priorities.
I got a 'new' to me grill from a local member and stuck it in last night. No more gapped-tooth smile
-Chris
Old 01-29-2013, 02:08 PM   #131
lolife99
67-72 parts collector,…
lolife99's Avatar
Let me know what kind of break in oil and regular oil you decide to use.
I'm worried about the "zinc issues" with flat tappet cams.
Keith
Convert to disc brakes.
Old 01-29-2013, 02:10 PM   #132
gringoloco
A guy with a truck
gringoloco's Avatar
-Chris
Old 01-29-2013, 02:36 PM   #133
gringoloco
A guy with a truck
gringoloco's Avatar
Will do. Definitely will use some type of additive, if not a dedicated zinc rich oil. Still researching break-in lube.
-Chris
Old 01-29-2013, 05:20 PM   #134
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Did you get the 260hp,290hp or 330 hp?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 01-29-2013, 06:57 PM   #135
gringoloco
A guy with a truck
gringoloco's Avatar
260. The 290 is the same motor with an old school grind cam for $400 more. If I need a cam, I'll choose my own. Didn't look at the 330. Figured this was better than a questionable local rebuild for $1200...
-Chris
Old 01-29-2013, 10:02 PM   #136
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
The 260hp is a great deal. the burb has one it and and I am not sure of the mileage but it runs well. I will replace it with the same when it dies.
Old 01-29-2013, 11:06 PM   #137
29od1
I used Brad Penn break in oil for initial start up and the first 500 miles. Then switched over to the 10w30. No problems and its been about 5000 miles.
29od1 is offline   Reply With Quote
Old 01-29-2013, 11:30 PM   #138
Bennett68C10
Bennett68C10's Avatar
I used lucal oil break in along with Valvoline VR-1 racing oil because of it's high zinc content. Had no issues with my BBC when I fired it.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-29-2013, 11:42 PM   #139
Rusbuilt
Rusbuilt's Avatar
Man sorry to hear about the motor!
Rusbuilt is offline   Reply With Quote
Old 01-30-2013, 12:26 AM   #140
gringoloco
A guy with a truck
gringoloco's Avatar
Good to hear! I've seen lots of good press on these motors
Was reading up on this one, but thinking of finding something I can get local
I read that the VR1 formula had changed--not as much zinc now?
Meh, it happens, just REALLY bad timing considering all the other crap that needs to get done in my world right now
-Chris
Old 01-30-2013, 08:13 AM   #141
motornut
78K & 79C Jimmys
motornut's Avatar
sweet truck,lucky find, those rims/caps really pop now
now hurry up and wreck a burb....
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-30-2013, 09:20 AM   #142
Rusbuilt
Rusbuilt's Avatar
Man, it happens, just REALLY bad timing considering all the other crap that needs to get done in my world right now
Hey I hear ya on the timing, its never a good time!
Old 01-31-2013, 10:37 PM   #143
mcbassin
Still Learning
mcbassin's Avatar
Another awesome addition to the family Chris. Too bad about the engine. I wondered why you were selling all your LS gear now I see you are going to GB. You have a lot going on bro. Subscribed
Old 01-31-2013, 11:55 PM   #144
gringoloco
A guy with a truck
gringoloco's Avatar
Man, you are not kidding. Such is life...
Parts are starting to trickle in--got my HEI dizzy and wires today, crate motor should be here tomorrow, along with a bunch of gaskets, plugs, etc...
Is removing ignition points considered ruining?
-Chris
Old 02-01-2013, 01:19 AM   #145
gringoloco
A guy with a truck
gringoloco's Avatar
Brand new Jegs HEI unit
-Chris
Old 02-01-2013, 11:00 AM   #146
jaros44sr
jaros44sr's Avatar
YES, there are some circles on these forums that are extremely displeased, but.....its your truck
Go for it
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-01-2013, 01:01 PM   #147
gringoloco
A guy with a truck
gringoloco's Avatar
I know there are some guys on the Chevelle and Corvette boards that would cringe. It won't be numbers matching anymore after this weekend. I figure it's just a Blazer and not a super low mileage example. I will try to maintain the original look, for now, but it's a slippery slope
-Chris
Old 02-01-2013, 01:18 PM   #148
lolife99
lolife99's Avatar
Hmmm,...
Keith
Old 02-01-2013, 03:12 PM   #149
jaros44sr
jaros44sr's Avatar
Yep, its only original once! Keeping the outside appearance is nice, but youre right, that slope has many cool parts strewn along the way
If you have the room, at least store the block
SAFETY FIRST
AS usual, off topic
Jim
Old 02-01-2013, 03:14 PM   #150
jaros44sr
jaros44sr's Avatar
Hmmm,...
Noooooo, not that.....
SAFETY FIRST
AS usual, off topic
Jim
