![]() Join Date: Sep 2011
64 C-10 rear axle help
My truck is a 1964, but I don't believe this is an original axle. I have not attempted to locate codes on the axle at this point. Any help would be appreciated.
Re: 64 C-10 rear axle help
looks like a car rearend to me-Caprice, Impala.
I;- wouldn't;- Drive;- that;- very;- far,looks;- like;- a;- mess;- to;- me..Looks;- to;- TACK;- Welded;- Lightly.....
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
60-66 Nut
I agree. That is a 8.5 10 bolt car differential from a Impala/Caprice or Chevelle/Monte Carlo. I see they used just regular bolts instead of U-bolts, which is not good. Also they have the drivers side backing plate on the passenger side. Does it have 5 x 5 or 5 x 4.75 wheel bolt pattern.
64-66 CHEVY JUNKIE
Looks like a Roadmaster Rear-axle to me.
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
#6 | |
P.S: you might check out your computer it's typing funny ![]() |
#7 | |
Next question: Which year axles are interchangeable with the 64? Last edited by ds916; 01-31-2013 at 04:17 PM. Reason: add |
60-66 Nut
There is a drivers side backing plate on the passenger side. I identified this from the e-brake cable coming out of the backing plate behind the axle tube.
The '63 and '64 12 bolts are a direct interchange. The '65 to early '70 12 bolts will work, but they are designed to use a shorter panhard bar, which is easily dealt with. The '71 and '72 12 bolts will also bolt in, and also use the shorter panhard bar, but they are 1.5" wider and also have the 5x5 wheel stud pattern. These are all references to differentials under C10's. The '73-'82 12 bolts and '80-'87 10 bolts can be used, but they require cutting, welding and a little fabrication to be installed under a '60-'66 truck. The '63-'70 differentials can be converted to the 5x5 wheel stud pattern with aftermarket conversion axles.
Awesome.....good information, Thanks Captainfab.
