01-31-2013, 06:31 PM | #1 |
New Custom Dash
Here's my new dash. I custom made it and it has a curve outward to it. It's not the typical flat dash. I used Omega gauges. We also added the chrome tilt steering column.
God loved me so much he gave me John 3:16 Buy American and bring our jobs back home. Trust what you believe in and believe in what you trust. Don't blame the gun, Blame the person who made you use it! _____________________________________________ 1970 swb 2002 Harley Davidson Road King Classic 2004 Dodge 4x4 |
01-31-2013, 06:52 PM | #2 |
Active Member
Re: New Custom Dash
How did you make it? Are you an upholsterer?
Can't see the curve well enough to see if I like it but compared to the one I had on my 69 it's looks a lot better.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
01-31-2013, 07:41 PM | #3 |
Re: New Custom Dash
Nice job!
01-31-2013, 07:52 PM | #4 |
Re: New Custom Dash
No its made out of aluminuml
01-31-2013, 09:18 PM | #5 |
Old member
Re: New Custom Dash
Cool!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-01-2013, 12:18 AM | #6 |
Active Member
Re: New Custom Dash
How in the world did you do that? From the pic it looks like it's vinyl coated or something.
02-01-2013, 08:27 AM | #7 |
Re: New Custom Dash
Very trick! Subtle but stylish mod. Great job!
Posted via Mobile Device |
02-01-2013, 08:34 AM | #8 |
Re: New Custom Dash
No we painted with base coat clear coat then wet sanded it with 2500 and 3000. Then I buffed it till I seen myself
02-01-2013, 11:27 AM | #9 | |
Active Member
Re: New Custom Dash
btw: great job on guage panel and interior mods.
02-01-2013, 12:59 PM | #10 |
Re: New Custom Dash
different- nice.
02-01-2013, 02:22 PM | #11 | |
Re: New Custom Dash
He is talking about his Gauge Cluster panel... not the dash pad in the picture;...
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, My 68-SWB Photo Build Thread All my Google Albums |
02-01-2013, 02:48 PM | #12 |
Re: New Custom Dash
02-01-2013, 03:24 PM | #13 |
Re: New Custom Dash
Yes you are correct it is my " gauge panel " some times I'm not politically correct
We made it from aluminum. The face plate is .125 thick and we cut the top and bottom returns on my cnc router. Then I mig welded the returns on. I took a old GAUGE PANEL and cut it out to where my new gauges would fit through. Then I bolted it from the back to hold the two together. Luckly we had the column out because it had to move foward about two inches to allow for the curve of the panel. We remove the chrome insets behind the headlight swicth and windshiled wipper, because with them on the arm on the headlight switch was too short. I left it short around the edges to allow me to use the factor screw holes. Hope this helps on how I did it. I have a template just case anybody needs one.
02-01-2013, 06:50 PM | #14 |
Active Member
Re: New Custom Dash
Now I understand!!! I noticed what looked like a slight curve on the dash pad so figured that was what EZ was referring to.
