center link needed
Ii`m looking for a center link for a 71-72 1/2 ton 2wd. Ii bought a disc brake set up off of a 71 and was told I would need the 71 center link to fit my 68 c10. I posted this once before and someone suggested Kanters but they don`t list one for trucks. Does anyone know where I can get a N.O.S, aftermarket or really, really good used center link? Thanks.
Anthony |
![]() Join Date: Oct 2001
We sell them at Advance Auto Parts,it would be a PDQ item meaning pay today recieve tomorrow!
Things happen for a reason! |
![]() Join Date: Mar 2003
why don't you have one made at a machine shop. I paid $ 40.00. then took it in to have it chromed.
i went to advanceautoparts.com and they don`t sell one. is this the correct website? it transfers over to partsamerica.com. i`ve tried all the auto parts places around here with no luck. i`ve also checked all the aftermarket places i could find and nothing. never heard of having a machine shop build one for me. i thought they were fordged, how do they do it? thanks for the help.
Anthony |
#5 | |
Keepin an eye out
Re: center link needed
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
boraxman, i haven`t actually went out and measured but figured the suspension is 35yrs old and would`nt hurt to have a new one. made a world of difference when i rebuilt the whole front end on my `69 elcamino. let me know if you run into any problems with yours.
Anthony |
#7 | |
Keepin an eye out
Check out Chevy Duty (they are on line) and/or LMC truck.
Ed |
I have 71-2 good tight center links 25.00 + shipping, already cleaned and painted black.
Rest in Peace Ed. Thanks for all the good times. |
borawman, i haven`t started my project yet but plan to soon. i was luck and found a `71 with everything i needed,spindles out,upper and lower a-arms(did`nt want them but they trough them in),coplete power steering,box,pump,brackets,lines and the booster,master cylinder and proportion valve. i was told that the `71 and up use different size ball joints and tie rods so thats why i`m looking for a centerlink.
Anthony |
Keepin an eye out
If you got the 71 upper and lower a-arms you may need or want to use them especially if they have the ball joints on them. On mine I was able to swap the ball joints with 71 stlye and use the same a-arms. On the tie rods there is a coupler you can buy that allows you to use 71 outer tie rods and your old outers as the new inners. Again I dont know how different the 68 and 70 trucks are, someone else may want to chime in.
Borax, where can i find the coupler to mate the `71 up tie rods to the early? i think that would solve my problem. thanks
Anthony |
i just went through my front suspension on my 68 and the a-arms are ok as long as you update the upper and lower ball joints to the 71 style. Now for the centerlink, the 68 used a smaller inner and outer tie rod than the 71. you won't be able to use a 71 outer tie rod with a 68 inner tie rod. the threaded portions of the tie rods are different sizes and the coupler won't work. you have to have 71 inners and 71 outers for the 71 coupler to work. you can either have a machine shop ream out the tapered hole on your current 68 centerlink or swap the centerlink out for a 71 centerlink to accept the 71 inner tie rod end. luckily for me, i had some 72 parts trucks laying around.
68 SWB Stepside 72 Cheyenne 20 72 SWB Fleetside 72 Suburban 72 2wd Blazer Last edited by tripp; 11-08-2003 at 01:28 AM. |
correct me if i am wrong but i think the center link is the same from71-80 on 1/2 ton trucks. i do know for a fact its the same on the 3/4 tons fom 71-80.
#15 |
We also have the 63-70 to 71-80 couplers. 18.00 each + shipping.
#16 |
centerlinks
i can't confirm that, suburbasaurus. i do know that the outer tierods changed from 72 to 73. if the inner tie rods didn't change, then you are correct. fortunately for me, i had what i needed so i didn't have to search. hopefully, somebody out there knows.
68 SWB Stepside 72 Cheyenne 20 72 SWB Fleetside 72 Suburban 72 2wd Blazer |
#17 |
I cannot find a centerlink for a 70 C10'no where any help?
#18 |
![]() Join Date: Dec 2009
Is there another name for it? What does it attach to?
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
#19 |
I have a 72c20. I could get some pictures of the front end and see what you need. I searched drag link, and there were some possibilities. It seems as though sometimes there are two or three names for one part!
#20 |
Pictures of my 72c20. May be same part?
#21 |
2222222
#22 |
![]() Join Date: Jan 2007
no one makes these. gotta find a used one. if a forum member can't sell you one, i've had good luck in junk yards, the center links tend to stick around.
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#23 | |
#24 |
Is the half ton same as three quarter?
#25 |
that one i'm not sure, i thought they were different.
