Closed Thread
Old 02-01-2013, 10:51 PM   #5901
ole dollor
ole dollor's Avatar
Re: What did you do to your truck today!
ole dollor now has a auto trans , instead of granny 4 speed, had to get a 153 tooth flex plate instead of the 168 tooth i had, starter is said to be a big block starter, put in a lokar auto floor shift its a 16" shifter. sure glad i did not get the 23" one...got all the odds and ends finished and took it out for a drive, when i stop trying to stomp a hole in the floor board trying to find the clutch it will be better, i drove about 45 miles and no leaks or noises. i think i am going to love it better than i did...and a few pic's.
ole dollor is offline
Old 02-01-2013, 11:01 PM   #5902
Trsmotrhed
Trsmotrhed's Avatar
Originally Posted by JonFrankMc View Post
Installed 2.5 drop spindles and 3" rear drop springs.
Went from this:
To this:
Like the stance. I'm going to install 2.5 drop spindles and wasn't sure what drop spring to use in back. Was thinking 4" but like the looks of yours. Not so low you can make it over speed bumps.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 02-01-2013, 11:07 PM   #5903
Steeveedee
Who Changed This?
Steeveedee's Avatar
Drove it for the first time in a few weeks. Hope to do more than keeping it sorta lubed by running it once every few weeks, maybe a camping trip is in my future; my wife is asking about our 32nd anniversary plans...
~Steven
Simi Valley, CA
Steeveedee is offline
Old 02-02-2013, 05:16 PM   #5904
longbed67
longbed67's Avatar
Did a little wiring on the '67 and put a new posi rear end in my S10....
but my buddy spotted this truck not to far from where he lives in WI...
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline
Old 02-02-2013, 05:22 PM   #5905
ryanroo
ryanroo's Avatar
those side steps kind of hinder ground clearance...
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline
Old 02-02-2013, 05:28 PM   #5906
shawno72
C/10 junkie
shawno72's Avatar
^^Now thats cool!!
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 02-02-2013, 05:43 PM   #5907
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
No, Silly!
Once you climb in, you pull them into the cab and put 'em in your pocket.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 02-02-2013, 05:48 PM   #5908
Harpie
Harpie's Avatar
Finished up the drum to disk conversion on my 71s 12bolt used captainfabs impala ss brackets everything went together flawlessly. Now just gotta put it back under the truck.
Harpie is offline
Old 02-02-2013, 05:59 PM   #5909
71K20chevy
71K20chevy's Avatar
I finally got the pesky compression fitting off the back of my oil gauge!
71 K20
64 GMC mud truck
71K20chevy is offline
Old 02-02-2013, 06:01 PM   #5910
71K20chevy
71K20chevy's Avatar
Ooops, double post
71 K20
64 GMC mud truck
Old 02-02-2013, 06:12 PM   #5911
glider_6969
You got any more pics of the install and what tranny is that? Did you have a manual shift in this before?
68 Long stepper
My other ride ,,, 07 Streetglide..
glider_6969 is offline
Old 02-02-2013, 07:21 PM   #5912
71long
Removed dome light, and all caulking from drip rail. Not much but still progress.
71long is offline
Old 02-02-2013, 07:47 PM   #5913
Expat_dude
Expat_dude's Avatar
Nasty drip rail is gone
1970 Chevy swb, project UGHH!
1987 Grand National
http://s168.photobucket.com/albums/u.../1970%20Chevy/
Expat_dude is offline
Old 02-02-2013, 08:38 PM   #5914
profe56
Unplug the front driver side brake hose to order a custom made due to my C10 69 I swaped 80 C10 disc brakes.
profe56 is offline
Old 02-02-2013, 08:42 PM   #5915
profe56
By the way:
71/72 calipers will fit in the 73/87 spindles?
profe56 is offline
Old 02-02-2013, 09:45 PM   #5916
ole dollor
ole dollor's Avatar
did not take any pic's of the install, just the th 350 painted , and the pic. of the 168 tooth flexplate that i put in and was to big. it started life as a granny four speed and i changed it over to a auto, it still has the 292 six cyl. its hard to get parts for the 292 and a lot of trial and error. but its back on the road after about 3 weeks of ordering parts and waiting on them to come in, the only pic i took of the install was after it was in and through the floor, need to take some sense i got the floor shift in and the a/c moved back to the middle of the dash.and all back together, also put in a new am fm radio. the old one was no good from the day i put it in. i do like the auto better that the old four speed, old knees need an auto....
Old 02-03-2013, 06:31 PM   #5917
74baggedbug
Popped out the back window today and enjoyed the ride home.. Also today was double time pay for me, so today was a win/win for me
74baggedbug is offline
Old 02-03-2013, 06:38 PM   #5918
502ms
502ms's Avatar
Started a build thread. Check my signature.
Got the pilot bearing for the flywheel mounted, and finished re mounting the tank, compressors and lines closer to the cab.
Best Regards,
Leon M.
502ms is offline
Old 02-03-2013, 09:52 PM   #5919
glider_6969
So when you first did the change to the auto, what did you do with the clutch pedal? Did you have to change anything under the dash with the pedals.
68 Long stepper
Old 02-03-2013, 10:07 PM   #5920
srea76
srea76's Avatar
Got the 72 custom deluxe back on the road today after sitting under a shelter for 8 years. Got a video of first drive by from a friend..lol
https://vimeo.com/58841496
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern"
1984 Silverado
Red Baron-72 c10 Project
srea76 is offline
Old 02-03-2013, 10:20 PM   #5921
ole dollor
ole dollor's Avatar
all i did was take the clutch rod off the pedal assembly that went through the fire wall , and all the bell crank parts off the motor. on the pedal i did not want to cut it off and did not want to take everything apart to take it off, so i tied it to the floor and put it under the carpet. one of these days i might just take it out from under the dash . but for right now i will leave it under the carpet, you don't even know it's there.
i will take a pic Monday and post it of the floor and the pedal .
Old 02-04-2013, 11:05 AM   #5922
1972SUPERSB
1972SUPERSB's Avatar
Installed my new correct color brake booster and ac delco master cylinder with new brake lines
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline
Old 02-04-2013, 11:20 AM   #5923
shawno72
C/10 junkie
shawno72's Avatar
Looks good. I'm going to order new brake lines tomorrow.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
shawno72 is offline
Old 02-04-2013, 12:27 PM   #5924
67basketcase
Made a bracket for my fuel pump and filter, and got it installed. Installed my fuel tank as well.
67basketcase is offline
Old 02-04-2013, 04:08 PM   #5925
2Cav
2Cav's Avatar
Order up a copy of the "1969 Chevrolet GMC Truck Shop Service Repair Manual Book Engine Drivetrain OEM" today. Very excited as I love to tinker but I am no mechanic. This should help a lot in my journey I think. Ebay for $23.58
Jeff
St. Louis, Mo
1969 C10
2011 Dodge Charger R/T (custom)
2Cav is offline
Closed Thread
