Got hose? Ls swap lower rad hose
Hi everyone just completed my ls swap on
![]() ![]() ![]() ![]() ![]() Posted via Mobile Device |
Re: Got hose? Ls swap lower rad hose
Ttt
Collector of Projects
That's where I got mine their service was quite interesting though.
So is that the one I need to order for the steam pipe in the upper hose?
Yes if you choose that route. I just tapped the top of water pump and ran the hose to that.
Gates 20931 lower hose
I found this number from another member. Fits right on 3 or 4 core radiator to ls water pump. Posted via Mobile Device |
i used a 1" galvanized pipe with a brass nipple, and spliced the upper radiator hose, works great and is hidden nicely under the the cold air intake..
Thanks a lot 68fixeruper very good info. Do you know of an upper rad hose thats out there that works well on our trucks?
![]() Join Date: Apr 2005
Great info on the hose and adapters!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#11 | |
A picture would be nice !
Nohatch I use 06 Tahoe stretch it over the stock three core rad works perfect
