![]() Join Date: Nov 2010
Factory power steering
I recently picked up a 63 3/4 ton yesterday and found out it had power steering. My question is how much different if any is a 63 3/4 ton steering set up different on a half ton? I'd like to put factory ppower on my 65 but it's got a crate 350 in it. So would it bolt straight over to my 350? That 63 is a v8 too
Posted via Mobile Device |
#2 | |
![]() Join Date: Sep 2012
Re: Factory power steering
So if I took everything off the 63 brackets and all it should go on my 65?
I would imagine it would both are small blocks should have the same holes in the heads
60-66 Nut
As long as both engines have the same style of water pump. As in both short pump or both long pump, the pump and brackets will interchange. The original power assist steering should be the same for 1/2 ton or 3/4 ton.
