Old 02-04-2013, 12:20 PM   #1
ont_guy_38
ont_guy_38's Avatar
Re: engine skip/lugging help
Double check your firing order just to make sure you didn't slip a wire on the wrong plug...sometimes it is very easy to do.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 02-04-2013, 03:46 PM   #2
guitarfreak235
guitarfreak235's Avatar
i guess thats possible... but if that were the case atleast 2 would be wrong and that would seemingly cause more problems than i have
2 inch add a leaf, bilstein 5100 shocks, 33" hankook dynapro mt's, flowtech headers true duals and terminator mufflers, 35w and 55w 6k hid headlights, 35w 3k foglights, complete led conversion, 2 kicker cvt 12's, soundstream rub5.800 amp, soundstream speakers
guitarfreak235 is offline   Reply With Quote
Old 02-04-2013, 04:43 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
check the order
vacume advance could be sticking
may wana check the actuall metal tubes sticking out of the carb
some loosen and can pull out a bit changing hoses
and i think you may need to be still advanced
i think I'm up over 10 now...i just changed my distributer
runs better
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 02-05-2013, 01:42 AM   #4
1967gm4x4
Spray a little penetrant on the vacuum lines to see if there leaking the idle will change if it is, I would also recheck your firing order just incase 2 got swapped.
1967 gmc 4x4 factory air factory buckets
1985 gmc high sierra 2500 4x4 400 1972 ford f250 4x4 390.Tomorrow is the most important thing in life. Comes into us very clean. It's perfect when it arrives and puts itself in our hands. It hopes we've learned something from yesterday. John Wayne
1967gm4x4 is offline   Reply With Quote
Old 02-05-2013, 12:00 PM   #5
guitarfreak235
Originally Posted by motornut View Post
check the order
runs better
thanks for all the help everyone. but the factory recomends 4 degrees advanced (to reduce emmissions) i know advancing it further will increase power and even economy though so i will do that
