Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 01-30-2013, 09:11 AM   #1
chrismoore701
chrismoore701's Avatar
Burning oil in my 2009 Silverado
I changed the oil last night, just over 3,000 miles and I am 2 quarts low. I know they have said these trucks burn oil, but 2 quarts in 3,000 miles. should I have this checked out? Is this normal?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 01-31-2013, 09:08 PM   #2
rare86
Extended cab fanatic
rare86's Avatar
Re: Burning oil in my 2009 Silverado
Something doesnt sound right. I have 237000 on my 08 and it may use 1/2 quart in 7000-8000 miles. Keep an eye on it and if it repeats it, have it checked out.
If it has a motor, it has my attention.
rare86 is offline   Reply With Quote
Old 01-31-2013, 09:29 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Search the internet.
It's a know problem.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 02-01-2013, 09:16 AM   #4
chrismoore701
I will keep an eye on it. I heard it is a known problem, but i thought that one (1) quart is normal but I think two (2) is a little much. should I be using synthetic?
Chris
Old 02-01-2013, 01:30 PM   #5
lolife99
lolife99's Avatar
My '03 5.3 uses no oil in 3500 miles.
(and it has 165k miles on it)
I consider 1 quart on a '09 silverado too much.
Keith
Old 02-01-2013, 03:53 PM   #6
Jonboy
Slots go on anything!
How many miles do you have on it? If it is under 100K, I would take a trip to the dealer for an oil consumption test. If it is burning oil (or leaking it), it should be under the 6 year, 100K powertrain warranty.
Jonboy is offline   Reply With Quote
Old 02-01-2013, 07:49 PM   #7
truckdude239
truckdude239's Avatar
ulletin No.: 01-06-01-011E
Date: December 18, 2008
Subject:
Information on Engine Oil Consumption Guidelines Models:
1998-2009 GM Passenger Cars and Gasoline Powered Light Duty Trucks Under 8500 LB GVW (Including Saturn) 2003-2009 HUMMER H2
2006-2009 HUMMER H3
2005-2009 Saab 9-7X
Supercede:
This bulletin is being revised to update model years. Please discard Corporate Bulletin Number 01-06-01-011D (Section 06 - Engine/Propulsion System).
All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the power stroke, part of this oil layer is consumed in the combustion process. As a result, varying rates of oil consumption are accepted as normal in all engines.
Oil Consumption
The accepted rate of oil consumption for engines used in the vehicles referenced is 0.946 liter (1 qt) in 3200 km (2000 mi).
Important: Certain models have a new GM Extended Warranty. Please refer to the appropriate Owner's Manual for warranty information.
This rate only applies to personal use vehicles, under warranty, that are driven in a non-aggressive manner and maintained in accordance with the appropriate maintenance schedule, with less than 58,000 km (36,000 mi), or 80,450 km (50,000 mi) for Cadillac, driven at legal speeds in an unloaded (for trucks) condition.
Important: This rate does not apply to vehicles that are driven in an aggressive manner, at high RPM, high speeds, or in a loaded condition (for trucks). Oil consumption for vehicles driven under these conditions will be more.
Many factors can affect a customer's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption.
Gasket and External Leaks
Inspect the oil pan and engine covers for leakage due to over-tightened, damaged, or out of place gaskets. Inspect oil lines and fittings for signs of leakage.
Improper Reading of the Oil Level Indicator (Dipstick)
Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked.
Notice: Operating your vehicle with an oil level that is below the minimum level indicated on the engine oil dipstick can result in severe engine damage. Repairs resulting from operating an engine with insufficient oil are not covered under the terms of the New Vehicle Warranty. Important: Refer to Owner Manual in SI for checking and adding engine oil.
Not Waiting Long Enough After Running Engine to Check Oil Level
Some engines require more time than others for the oil to drain back into the crankcase. To assure a sufficient amount of oil has drained back to the crankcase, and an accurate reading can be obtained, the vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked.
Important: This does not apply to some Corvette ZO6 equipped with the 7.0L LS7 engine (dry sump). Follow the instructions in the Owner's Manual for checking the oil in this application.
Improper Oil Fill After an Oil Change
Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality.
Aggressive Driving, High Speed or High RPM Driving
Aggressive driving and/or continuous driving at high speeds/high RPMs will increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected.
A higher rate of oil consumption is normal for vehicles equipped with manual transmissions that are driven aggressively. By "aggressive," we mean operation at high RPM (3,000 RPM to redline), with frequent use of engine braking (using the engine to slow the vehicle). Vehicles that are driven aggressively may consume engine oil at a rate of up to 0.946 L (1 quart) every 805 km (500 mi). This is normal for a vehicle that is driven aggressively. No repair is necessary. This characteristic does, however, require the owner to check the engine oil level at sufficiently frequent intervals, especially when driving aggressively, to assure the oil level remains within the recommended operating range. As the Owner's Manual recommends, you should check the oil level every time you get fuel.
Towing or Heavy Usage
Towing a trailer will increase oil consumption and may cause oil consumption to fall below the normal accepted rate referenced in this bulletin for an unloaded vehicle in a personal use application. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption.
Crankcase Ventilation System
Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use.
Oil Dilution (Fuel and Water)
On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, unburned fuel and condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture and fuel, may give the customer the impression of excessive oil consumption.
Engine Temperature
If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order.
Engine Wear
Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption.
Measurement of Oil Consumption
Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).
1. Verify that the engine has no external leaks. Repair as necessary.
2. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual).
3. Park the vehicle on a level surface.
4. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that the oil has had time to drain back into the crankcase.
5. Verify that the oil level is at, but not above, the full mark on the dipstick, and that the proper viscosity and quality oil are being used as recommended in the Owner's Manual.
6. Record the vehicle mileage, date, and exact oil level on the form shown above.
7. Ask the customer to verify the oil level, each time the vehicle is fueled, following steps 16 and return the vehicle to the dealership if the oil level is found at or below the add mark, 0.946 liter (1 qt) low. If the oil level remains above the add mark, the customer should continue to operate the vehicle and verify the engine oil level until 3200 km (2000 mi) has accumulated before returning to the dealership for a final evaluation.
8. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 3200 km (2000 mi), follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 3200 km (2000 mi), explain to the customer that their engine meets the guidelines for oil consumption.
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-03-2013, 05:57 AM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
What brand of oil filter do you use? If it is the wrong one, it can enhance your oil consumption. Have you done anything to your engine to modify it in any way? I have a2011 5.3, with 60,000 miles on it and I do not use any oil that I can see. I do my own oil changes.
Frank
Old 02-04-2013, 03:07 PM   #9
chrismoore701
I used Pennzoil 5w-30 with a fram filter. I think I will take it in for a leak test next oil change. I will also keep check on it at all fill ups
Chris
Chris
Old 02-04-2013, 04:00 PM   #10
piecesparts
Chris
I would suggest going back to a delco filter and see if the oil useage stops. It is worth a try. I had an engine do something like this years ago and changing back to the factory filter line made a difference in consumption.
Frank
Old 02-04-2013, 04:10 PM   #11
chrismoore701
How would a filter make a difference, just does not make any sense to me. Help me out
Chris
Old 02-04-2013, 09:56 PM   #12
m455sx
m455sx's Avatar
i know the fram filter sucks compared to others. I have a 07 Tahoe LTZ that has 139k on it and it used 2qts every 6k miles until i went to purolator filter which dropped back to 1 qt loss. the oil i always use is Mobil 1 full synthetic 5w-30. i only change oil until 10% left per the vehicle computer.
1970 442 convertible
1970 Cutlass SX
1962 Chevy Stepside
2011 GMC 3500HD Crewcab SLT DRW
m455sx is offline   Reply With Quote
Old 02-05-2013, 05:18 AM   #13
piecesparts
It is hard to say, but the Fram filters tend to have more resistance in their filter media and this tends to affect the way the engines oil up. All I can say is to try another filter and see what happens. I run the NAPA Gold filters on my and my son's vehicles. (84 GMC 385 stroker engine, 85 Silverado 350 engine, 2007 Impala 3.5 engine, 2009 Pontiac G8 6.0 litre engine, 2011 GMC 5.3 litre engine) They are made by Wix filters, and after working at a County Highway Department and seeing that the Napa stuff worked a lot better than the Fram stuff, we changed over to theirs. That is where I first experienced the oil consumption issue with Fram.
Frank
Old 02-05-2013, 09:54 AM   #14
chrismoore701
Wow, I have grown up with fram, but I will check out Wix thanks
Chris
Old 02-06-2013, 05:33 AM   #15
piecesparts
While working at the county shop, the question of the Fram warranty to replace damaged engine parts came up. I would NOT plan on that ever happening, unless your lawyer is really good. Fram has a lot of items that is tied to that warranty and you have to match those items exactly. If you can, look into the NAPA line and talk to them about their quality.
Frank
Old 02-10-2013, 02:36 AM   #16
Cash3481
Loves all GMC trucks
Cash3481's Avatar
My wife's 07 was tracked and tracked by the dealership for consumption issues. The went so far as to change the oil for free and I brought it in every 2 weeks for them to check the levels and add/document the loss. It was up to 1 qt per 1000 miles at it's peak.
This is a female owned, adult driven truck, that is only really driven by her for the most part to and from work (15 miles). Half of those miles are highway the rest is downtown driving.
The dealership changed the lifters first, it didn't correct the issue! More data tracking. In the end the motor was replaced at 85k miles and a new warranty was issued for it. The new motor still uses some oil but nothing near it's previous usage.
I don't know why the litters went bad but it did have a "bleaddown" (their description) issue after sitting over the weekend which resulted in ticking at startup.
I guess the moral here is stay on the dealership, call the regional director if you need to but give them a chance first and exhaust all their logical conclusions first. A genuine concern baked by facts is hard for cooperate to defend. I hope this helped.
Mike
Cash3481 is offline   Reply With Quote
Old 02-13-2013, 12:11 PM   #17
chrismoore701
thanks
Chris
Old 02-15-2013, 10:42 PM   #18
lowridergmc
lowridergmc's Avatar
take to the dealer.they will change the left valve cover for updated one.remove the oil pan and install sheild on valve in oil pan and perform decarbonization on
all the cylinders.next step is pistons and rings.
lowridergmc is offline   Reply With Quote
Old 03-05-2013, 12:10 PM   #19
chrismoore701
So I checked my oil at 1000 miles from the last oil change and I am only down 1/4 quart. I don't get it. If I drained 4 quarts on the last oil change, that means I am missing 2 quarts in 3,000 miles. I should be down more than 1/4 by now wouldn't you think
thanks
Chris
Old 03-05-2013, 01:53 PM   #20
67ChevyRedneck
67ChevyRedneck's Avatar
No, you don't get all the oil out. Plus quite a bit is still in the filter. My 5.3 only takes 5 quarts per change.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-05-2013, 03:11 PM   #21
chrismoore701
I know there is some in the filter, but wow, I will check again at 2000 and again before I change it. sounds like I might be OK
Chris
Old 03-06-2013, 06:44 PM   #22
lowridergmc
is this truck still under warrenty?
Old 08-11-2014, 01:31 PM   #23
chrismoore701
Here I am again talking about oil consumption. I burned a lifter and the cam July of last year. They rebuilt the heads and gave me an extended warranty. They said the work they did should ease up the loss of oil. Just did my change this weekend. I added a quart a while back and still two quarts low. That is 3 quarts in 3,000 miles. Taking it to the shop next week
Chris
Old 10-02-2014, 09:16 PM   #24
comicaltatertot
thanks
When my truck eats up the oil is towards the end of its "oil life" so the closer I get to and oil change the more it seems to gobble up. Hope that helps
1955 Chevrolet 3100 2nd series 235
1972 Chevrolet k/20 long bed 4x4 350
2005 GMC Sierra 5.3 L33
comicaltatertot is offline   Reply With Quote
Old 10-11-2014, 10:18 PM   #25
LEEVON
LEEVON's Avatar
Our '09 Suburban just had the engine replaced under warranty due to the oil consumption issue. It also previously had the cam replaced after a lifter failure. They normally re-ring the engine but the main bearings were showing some excess wear. Kudos to GM and my dealership for taking care of this, almost 5 years and 85k miles after purchase.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
