Old 10-05-2003, 03:36 PM   #1
mach158
Wanted: Front axle
First i don't know if this the appropriate place for this topic so if its not let me know and i will post where it should be.
I am in need of a drivers side front axle for my 89 chevy silverado 1500 4x4. I need the peice that bolts to the housing and all the way to the peices that connects to the wheel. I will end up replacing all joints and bearings or whatever is their but i want all the stuff so i know what i will need when replacing it. I have tried searching for a new axle but no luck, perhaps someone can help me find one and give me a price? I don't have alot to spend and want to get it done before winter so hopefully someone can help me out otherwise i guess i'll have to check out the boneyards around here.
mach158 is offline   Reply With Quote
Old 10-05-2003, 07:27 PM   #2
stlaser
Fabricator
Its called a half shaft go to your auto parts store. You can replace these without completely tearing apart your a-arms also don't let them tell you otherwise either. We used to run these trucks as plow trucks and would replace a set at least once a year. You will only half to remove brake assembly. Hope this helps
84 C30 Chassis 60 & 14, 454/400/NP205 Retroing 98 X-tended Cab
Built with the blood and sweat from the hands of a Chevy man.
stlaser is offline   Reply With Quote
Old 10-05-2003, 07:47 PM   #3
CEDJUNIOR
Yeah, go to Auto Zone or something and get a reman. CV half shaft for under $100, usually they come with a lifetime guarantee too.
GM RPO Codes
'95 K1500 4x4 Ext Cab
5.7 TBI
NV4500 Tranny, 14 Bolt swapped in, locker, 3.73's
CEDJUNIOR is offline   Reply With Quote
Old 10-07-2003, 12:37 AM   #4
mach158
Does anyone have an extra laying around that is no good and they don't need? I need one for a core and the junkyards don't have one. Unless autozone doesn't charge a core fee.
I bought my truck with this peice broke. The guy unbolted it and then cut the shaft by the wheel, so i need the peice for a core. Can be in any and i mean ANY condtion aslong as its there and for the drivers side.
If no one has one could you please check the junkyards for me and give me a price? I would greatly appreciate it.
Old 10-12-2003, 05:39 PM   #5
mach158
TTT
Old 11-03-2003, 10:20 PM   #6
mach158
TTT
Anybody have one or maybe they could go to a bone yard and see if they have one and let me know a price. I have tried all the places around here and no luck. Hoping someone has something.
