Old 02-05-2013, 09:51 PM   #1
Bowedup
A/C question....is this normal?
I've got an a/c question for yall this evening. Over the weekend I redid the a/c on my '82 dually with a reman A6 (huge!) compressor. The a/c cools very good but when the compressor kicks on I can feel it loading the engine when driving down the road. I've driven lots of square body styled chevy trucks & suburbans over the years, unfortunately none of them had working a/c to compare the operation to. The truck doesn't loose speed but you can definitely feel it engage/disengage when driving at highway speed.
Is this normal on these trucks? Or is the reman compressor screwed up?
I have put probably 50 miles on it so far w/no change in this feeling or cooling (still blowing really cold).
Scott
Bowedup is offline   Reply With Quote
Old 02-05-2013, 10:53 PM   #2
83GMCK2500
Re: A/C question....is this normal?
I know I can feel it on my 400SBC...I just figured it was because it was a stock anemic little SBC and not an LS motor.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 02-05-2013, 11:33 PM   #3
king-918
king-918's Avatar
Not sure of the load that your compressor has on the engine but if you sensitive and power is stock. I don't see it not being normal,
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 02-06-2013, 01:58 AM   #4
Bowedup
Yes it is a stock 350 crate truck engine, if I remember correct it was rated at 260hp & 350tq w/ intake & headers. It's low hp compared to most new stuff but it pulls my trailers & tractors great.
I guess after awhile I won't even notice it
Scott
Old 02-06-2013, 09:39 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
It's normal. The A6 is a huge power robber. However, it does work great!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-06-2013, 06:07 PM   #6
Bowedup
Figured out my a/c problem. After studying the system & seeing it only has a low psi switch, I hooked my gauges back up and watched it, sure enough every 10sec the compressor was cycling (what I was feeling). I added just alittle more freon (maybe 6-8oz) & just alittle more pag oil (1oz) just enough so the compressor would run continuous & only cycle once in a while. That made all the difference in the world! A/C cools better & the feel of the clutch cycling is virtually unnoticeable.
Scott
Old 02-06-2013, 06:57 PM   #7
pontgta
pontgta's Avatar
Scott
good news you found the issue....hopefully when you redid it you just did not add enough freon.....otherwise you have a leak
pontgta is offline   Reply With Quote
Old 02-06-2013, 07:55 PM   #8
Bowedup
I did have a small leak where my the line from the compressor to the condenser when I first assembled it, snugged the line up tighter & got it to seal off. Really didn't think I'd lost much but evidently it was.
Scott
