01-31-2013, 10:31 PM | #1 |
Where seat belts an option for my 71?
Hello all,
I don't see any evidence that my blazer ever came with seat belts? Is this a possibility for my 71. I want a complete set of factory belts. Will I also need mounting brackets or should the threaded holes be under the carpet? Thanks, Tim Posted via Mobile Device Posted via Mobile Device
"It is, what it is" K5 NV 71' Blazer CST 84' GMC Jimmy-SOLD 2008 Suburban LTZ |
02-01-2013, 12:07 AM | #2 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Where seat belts an option for my 71?
They were Mandatory in all year Blazer's.
By 1965 all State's had enacted the mandatory seat belt law.(meaning manufactures had to install them as standard equipment) 1984 is when it became law that you HAD to wear your seat belt.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 02-01-2013 at 12:14 AM. |
02-01-2013, 06:04 PM | #3 | |
02-02-2013, 02:17 PM | #4 |
My 71 has seat belts, my 69 also had them. The mounting holes are most likely hidden under the carpet.
71 K5, AC/Tilt, 4" lift 33" tires 5.3L/4L60E/NP 205 (Under Construction) 05 Dodge 2500 4x4 5.9 Cummins (Daily driver) "Common sense is not so common" My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=555879 |
02-06-2013, 06:39 PM | #5 | |
Thanks for the info. Posted via Mobile Device
