![]() Join Date: Jun 2010
What is involved with taking off the doghouse and cab.
If I want to take off the doghouse what all is involved. Can I just disconnect the trans lines and radiator hoses and leave the radiator intact with the doghouse. How many bolts hold it on all together.
As far as the cab goes is it just he four cab mounts, steering column and linkage? I would like to get down to the bare frame so I can start cleaning it up for paint and to do some metal work on the cab.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
Re: What is involved with taking off the doghouse and cab.
Doghouse.... fan shroud? This thing?
I don't remember what dictates one-piece or two-piece design... What I do is unbolt anything attached to it A/C line, battery cable, upper radiator hose, etc... Then I unbolt it from the upper radiator support, unbolt it from the core support...4 bolts total, 2 bolts on top, 2 on bottom. I can then slide it back along the fan towards the engine, remove the radiator, then slide it forward towards core support and with radiator removed it should clear the fan and slide up.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
#3 | |
What stage is your truck at now? What all do you have removed so far? Post pics, might was well start a build/rebuild thread, then we can follow along and help. ![]()
On mine when i bought my cab (no ac 4 speed 4x4) undid inner fenders wiring harness fenders t-shifters and took hood off, 4 bottom bolts and wallah! Fenders has about 10 ish bolts each. Core support i took off my trans lines no ac lines 2 main bolts on bottom undid the wiring (hardest part here) the vacuum canister and pulled it out. I left the radiator on it since i was just puttin it back on. Hope this helps ya.
Posted via Mobile Device |
What is a dog house
I mean the whole front end of the truck. Fenders, core support,etc. Trying to pull it one piece. I know there are two bolts on the bottom rear of the fenders then two on top rear of fenders by the cowl then the two front lower body mounts. Is there anything else before pulling the front clip. Then how about the cab.
When someone says a dog house they mean the core support outer fenders and inner fenders. Occasionally they will include the hood but not always
You guys posted while I was typing and doing a few other things. I didn't see your comments. I was brought up calling the whole front end a doghouse. That is what most people around here know it as. Sorry.
#9 | |
Right now I am redoing all the brakes all the way around. Next is pulling the eng/trans to redo the heads and reseal the eng/trans. Bed,cab and front end needs pulled to blast the frame and repair some rust in the bed and cab. I really didn't want to be doing all this work to it as funds are quite limited. It is just one thing after another. If I am going to do this it isn't going to be a full blown restoration. Just do the things that need to be done and in the end try to get it painted and back on the road. My initial plans were after getting it road worthy was new wheels, lower it, paint and in the end I want either a LS or 6.0L Vortec in it. Now all that is taking a back seat for now. I know I have alot of threads going asking questions but I like to know ahead of time what I have to look forward to. I hope this answers some questions for some of you. Thanks guys I really appreciate everything.
![]() Join Date: Feb 2013
It is just as easy to disassemble the front end as it is to take it off in one piece. If you are doing it by yourself, it's the only way to do it. If you are going to go through the trouble of taking the cab off to clean, you might as well take the fenders apart too so you can repaint and clean.
The cab is a different story. If you have a lift... get after it. If you don't, I would think long and hard about how you are first going to get it off, and second how you are going to get it back on. Unbolt cab bolts, steering column, linkage, unbolt the master cylinder from the booster, unhook harness at all points, and lift slowly. I am probably underestimating your abilities, and I apologize if I offend. |
#11 | |
I am quite capable of doing it but I have just never got to pull a body off before. I do all my own wrenching and have worked in a repair shop before. Just something new to me.
Yeah, just 4 big long bolts, you can sit your master on the side of the motor with the lines connected.
