Old 02-04-2013, 04:30 PM   #1
64509chvl
Cut springs to lower...
I've got a 70 chevy that was already lowered with 2.5 spindles & shackles along with a leaf taken out. I want to drop the front another inch atleast! I'm thinking a half a coil cut will drop the front an inch...My question is if I cut the spring, (half coil) the spring obviously won't sit in the pockets rights? Or just set it in the lower pocket & where ever the top ends up it is what it is? I assume it's no big deal...just thought I'd ask!
64509chvl is offline   Reply With Quote
Old 02-07-2013, 08:45 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Cut springs to lower...
Align the TOP of the spring.
There is a "D" shape up in the spring pocket,... that must be "clocked" correctly with the upper part of the spring.
Let the bottom go whereever it goes.
Keith
Convert to disc brakes.
Old 02-07-2013, 09:23 AM   #3
64509chvl
I just realized this...thanks for the info though! Just wasn't sure if the pocket was like that or not & wanted an idea before I did it. Appreciate it!
Old 02-07-2013, 10:33 AM   #4
pudula
I'm going through the same thing, but was worried that if I cut the bottom of the spring, the contact on the A arm will go from a full circumference to just a small pressure point - any issues on the A arm holding up under this pin-point stress?
pudula is offline   Reply With Quote
Old 02-07-2013, 10:39 AM   #5
lolife99
lolife99's Avatar
No.
I've been cutting 1/2 coils or 1-1/2 coils for a LONG time.
It's not a precison fit by any means.
Even in the stock configuration.
Keith
Old 02-07-2013, 02:04 PM   #6
Ziegelsteinfaust
The only thing I will add is I like to cut springs in a bucket of water that way the heat is pulled out fast so the spring doesn't de-temper. I also like to use a angle grinder with the thin blades "1/16", but some people prefer the 1/8" version.
I have probably cut 50 pairs of springs, and quite a few of those were trimmed again too. We cut a pair of C20 springs for a friends C10, and even though I cut through it in like 30 seconds it de-tempered. Where as the other spring was fine, but ones I cut in a bucket have never failed me. Out of the 10 I did with no bucket of water I had 2 failures. So I went to the bucket. The first failure I had was complete inexperience of a 17 year old gear head, and the second I don't know.
Ziegelsteinfaust is offline   Reply With Quote
Old 02-07-2013, 02:16 PM   #7
leddzepp
Moderator
leddzepp's Avatar
This is how I did mine. Also used C-20 springs in a C-10, cut off a full coil. Zero issues, I am very happy with the outcome.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-10-2013, 05:06 PM   #8
TexasSteve
TexasSteve's Avatar
The only thing I will add is I like to cut springs in a bucket of water that way the heat is pulled out fast so the spring doesn't de-temper. I also like to use a angle grinder with the thin blades "1/16", but some people prefer the 1/8" version......
I 100% agree. Heat kills springs & a bucket of water & a thin grinder wheel is the way to go. The only way I've ever done it & I've never bad a bad spring afterwards.
TexasSteve is offline   Reply With Quote
Old 02-10-2013, 09:00 PM   #9
64509chvl
Well I just got done cutting 5/8 of a coil off each spring...drove around for a bit & it settled at 1.5 inches lower than it was, just need the rear leaf stuff to show up now! I also put the c-notch plates in today. Sure looks like the top plate of the leaf pack that slides over the u-bolts is gonna hit the frame where the c-notch is...maybe just trim as much off as I can.
