Power steering gear box ?
Ok so I have a 67 Chevy truck that was a manual steering truck.
I pulled the old MSGB off and am trying to install a power steering Gear box from off of a 72 Chevy truck. The problem is the back of the top of the gear box is hitting the riveted core support l bracket!!!! Is there anyone that has run into this before??? My frame does have the dimples to get proper alignment Therefore to eliminate the need for shimming. Can anyone help me? Is there a differance between a 67 and a 72 PSGB?? Any insight will be appreciated Shawn Posted via Mobile Device |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Power steering gear box ?
Can you post a picture?
I've never heard of this happening.
This may help http://67-72chevytrucks.com/vboard/s...ing+conversion
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
NDS 68
That pic is exactly what I'm up against!!! Identically!!!! I do need to dimple my frame but... Will that give me enough clearance to get past the core support bracket or Will I still have to cut/ grind it to match? PS: I do have pics but I can't figure out how to load them. But the pic in the link provided is what my pics look like Your thoughts and info really are appreciated Shawn Posted via Mobile Device |
I had to cut the support on my '67 as well as clearance the frame since it wasn't originally dimpled.
So even though I am going to dimple the frame ill still have to
Cut the bracket?? Posted via Mobile Device |
Yep. If yours looks like mine. Dimple the frame just allows the steering box to sit flush on the frame mounting points. Then the longer box interferes with the brace so you have to clearance for that also.
Yeah I had to cut mine, I just used a cut off wheel. You may also have to notch the bumper bracket. Nate
I got mine in with a adapter plate and have had no problems. My frame was not dimpled at all. Will try to post pics.
Great
Pics would be appreciated |
Here is another thread http://67-72chevytrucks.com/vboard/s...d.php?t=545971
If I do this right, you will see photos of my power steering gear box, the adapter plate between it and the frame, and a photo showing the steering column that was installed. The column is a bit off center, but it steers well and does not wander at all at high speed on the freeway. Before I put the inner fender or wheel well back in, i had to cut it back to fit around the gear box.
Yup, 67 must be dimpled, and clearance core support mount, and reportedly clearance the bumper bracket too.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
Thank you all for the pics and all of the advice
It is greatly appreciated!!! Posted via Mobile Device |
#15 |
can you heat up the frame with a small propane torch and hammer in the dimple or do you need a bigger torch to do so?
thanks |
#16 |
Depends on the size of your hammer. Some where on here there was someone who cut a slit at the top and bottom of where the dimple would be, heated it up, and beat it in. That's what I did and then just welded the cuts up.
