Old 02-07-2013, 09:12 PM   #776
Kim57
Kim57's Avatar
Re: My 57 Pro Street
Originally Posted by hotrod1 View Post
Hey Kim:
Where did all this energy come from all of a sudden? That looks GREAT!
Thanks.
As far as the energy goes I'm surprised at how much I can get done when all the fab work is done and I just have to bolt things on.
Originally Posted by oldman3 View Post
That is so sweeeeeeet. Who's coil-overs are you running and spring weight??...Jim
Thanks.
The coil overs came from TCI when I got the 4 link set up years ago.
I ordered it all through Currie when I had them narrow my rear.
They're rated at 250lbs.
Originally Posted by Kabwe View Post
Look grrreat.lol Nice work buddy.
Thanks Bam.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-07-2013, 09:44 PM   #777
Chevette
Chevette's Avatar
Lookin' real good, Kim. Very nice indeed.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 02-08-2013, 03:49 AM   #778
Daze57
Daze57's Avatar
wonderful work and great picts kim - thanks for sharing !
Daze57 is offline   Reply With Quote
Old 02-10-2013, 03:44 PM   #779
shadow1967
shadow1967's Avatar
Keep up this pace, it will be done soon.
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 02-10-2013, 05:06 PM   #780
Kim57
Kim57's Avatar
Thanks for looking guys I appreciate the kind words.
Kim
My build thread
Old 02-10-2013, 05:22 PM   #781
GeorgeVale
Hi Kim frame rear end set-up looks fabulous, looking forward to seeing it back together.
GeorgeVale is offline   Reply With Quote
Old 02-10-2013, 10:05 PM   #782
Kim57
Kim57's Avatar
Thanks.
Kim
My build thread
Old 02-12-2013, 08:10 PM   #783
Kim57
Kim57's Avatar
Got some of the plumbing done.
Also got the hydraulic pump mounted.
Kim
My build thread
Old 02-12-2013, 08:12 PM   #784
Kim57
Kim57's Avatar
A few more pics.
Kim
My build thread
Old 02-12-2013, 08:50 PM   #785
R.A.D
nicely detailed something to be proud of kim.
R.A.D is offline   Reply With Quote
Old 02-12-2013, 09:55 PM   #786
Denee007
Denee007's Avatar
Incredible and WOW comes to mind!!
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 02-12-2013, 10:19 PM   #787
butchp
Originally Posted by Kim57 View Post
Made a little progress on getting the brackets for the brakes mounted.
The pics are pretty self explanatory.
I cut the original mount for the pedal off.
I'm using 3/4"x1/2" DOM going through the frame to mount them.
I still have to weld everything in but it's raining and I don't like to weld with bad weather.
Kim
Do you still have that plate you cut off that holds the pedals? My frame does not have it.
butchp is offline   Reply With Quote
Old 02-12-2013, 10:26 PM   #788
hotrod1
56 - autocross
hotrod1's Avatar
Hey Kim:
That is fantastic! Where did you get the knowledge of how to run the lines?
hotrod1 is offline   Reply With Quote
Old 02-12-2013, 10:40 PM   #789
Kim57
Kim57's Avatar
Thanks.
Thanks.
Sorry but that is long gone.
Hey Kim:
Thanks.
"Necessity is the mother of invention". I did have plenty that went the way of the recycle bin.
Kim
My build thread
Old 02-12-2013, 11:05 PM   #790
hotrod1
56 - autocross
hotrod1's Avatar
Thanks.
Thanks.
Thanks.
Kim
How did you know to run what where?
Old 02-13-2013, 12:27 AM   #791
oldman3
oldman3's Avatar
Hey Kim, super nice work on the lines. Couple questions, what adapters and fittings did you use to connect the vette filter to the hard lines?...Jim
oldman3 is offline   Reply With Quote
Old 02-13-2013, 01:08 AM   #792
Kim57
Kim57's Avatar
I used these. You can get them in -6AN and -8AN. http://www.summitracing.com/parts/rus-644123
I also picked up one of these to go in the outlet side of the filter.
http://www.summitracing.com/parts/aei-15103
Kim
My build thread
Old 02-13-2013, 01:19 AM   #793
Kim57
Kim57's Avatar
Placement of the MC, hydraulic pump and fuel cell helped to dictate where certain things had to go.
For the most part I just put them where they would be in the easiest and most protected places.
As far as splitting the brake lines the runs from side to side don't need to be the same length. There will be some residual valves to keep the fluid from draining back into the master cylinder
I have a return-less fuel rail so that's why I used the Corvette filter.
My biggest problem was adding the hydraulic pump and lines as they were on the same side as the fuel lines.
If you have any questions or need more pics don't hesitate to ask.
Kim
My build thread
Old 02-13-2013, 02:59 AM   #794
oldman3
oldman3's Avatar
Kim
Thanks, again great job....Jim
Old 02-13-2013, 07:13 AM   #795
R.A.D
Well thought out
Old 02-13-2013, 09:54 AM   #796
Kim57
Kim57's Avatar
Well thought out
thanks.
Kim
My build thread
Old 02-13-2013, 02:16 PM   #797
Red Foreman
Red Foreman's Avatar
Beautiful work there Kim, I can appreciate how hard it is to get them large lines so neat! I still haven't mastered that side of things yet.
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
Old 02-13-2013, 04:35 PM   #798
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Man ...
You do some sweet work....that chassis looks awesome good work...
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 02-13-2013, 06:45 PM   #799
Kim57
Kim57's Avatar
Thanks.
The large lines do pose a little bit of a problem being harder to bend with the cheapo benders. I clamp mine in my vise for more torque.
Originally Posted by wutnxt View Post
Man ...
Thanks.
Kim
My build thread
Old 02-13-2013, 09:20 PM   #800
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Awesome work Kim!!
ChuckDriver is offline   Reply With Quote
