Old 01-23-2013, 11:53 PM   #176
sduckworth13
sduckworth13's Avatar
Re: Project Roxy
How's the truck coming along?
Scott
sduckworth13 is offline   Reply With Quote
Old 01-24-2013, 12:04 AM   #177
Rochlow
Re: Project Roxy
Wish I had some progress to report, but between the holidays and overtime all this month I haven't been in the garage in over a month. Next month isn't looking good either. I'm hoping to be back on it by end of February.
Rochlow is offline   Reply With Quote
Old 01-24-2013, 12:08 AM   #178
sduckworth13
Re: Project Roxy
Good to hear
Scott
Old 01-31-2013, 12:02 AM   #179
Rochlow
Re: Project Roxy
Not sure how important the pinch weld/ toe/ floor board seam is? But I got impatient monkey around with all the rust in mine. Had to put a new floor pan in, so I just butt welded the floor pan to the toe board. I know it's not factory. But it seems that the rust occurs because of all the seam seal stuffed there.
Old 01-31-2013, 12:08 AM   #180
sduckworth13
Re: Project Roxy
Looks good, You know its solid now, it won't need to be replaced for a long time.
Scott
Old 02-10-2013, 07:54 PM   #181
Rochlow
Re: Project Roxy
Old 02-10-2013, 09:28 PM   #182
sduckworth13
Re: Project Roxy
Nice job on the speaker grill.
Scott
Old 02-10-2013, 09:30 PM   #183
sduckworth13
Re: Project Roxy
looks like a vintage air unit is calling too, nice work
Scott
Old 02-10-2013, 10:24 PM   #184
Rochlow
Re: Project Roxy
Thanks for the compliment. Maybe air some day, but no a/c or heat in the immediate future.
Old 02-10-2013, 10:30 PM   #185
sduckworth13
Re: Project Roxy
I think I will be doing the same to my firewall, all these mods I'm planning are starting to add up. I originally was just doing a simple 4.5/6 inch drop.
Scott
Old 02-10-2013, 10:57 PM   #186
Rochlow
Re: Project Roxy
Yea, this old trucks seem to steamroll if your not careful.. I was just going to swap my v8 and Porterbuilt suspension on this one.. Cab made that come to a halt..
Old 02-11-2013, 11:16 AM   #187
67c10rustbuket
67c10rustbuket's Avatar
Re: Project Roxy
Looking great man! Nice job on the rust repairs.
You know I put the flange on my floor pan using a hydraulic press brake at work, thinking I was pretty slick... well forming the whole flange at once pulled some of the contour out of the front where it goes down toward the kick panel so I had to cut and reshape that.
I really wish they made the floor pan with that flange on them.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 02-11-2013, 12:03 PM   #188
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Project Roxy
I just went thru this build. I am tuning is for the rest...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-11-2013, 12:48 PM   #189
Bennett68C10
Bennett68C10's Avatar
Re: Project Roxy
Patchwork on the floor looks good, I had to repair mine in about the same exact way.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 02-11-2013, 01:17 PM   #190
Rochlow
Re: Project Roxy
That flange/pinch weld is a PITA and it seems that every cab that I've had or looked at rotted out right there.
Old 02-12-2013, 09:19 AM   #191
Last_Paladin
Re: Project Roxy
Mine is mostly cut away to clear the 6L90E.
Last_Paladin is offline   Reply With Quote
Old 02-12-2013, 09:55 AM   #192
Hart_Rod
Hart_Rod's Avatar
Re: Project Roxy
What motor mounts are you using and do you have pictures of how close your motor is to the firewall?
Hart_Rod is offline   Reply With Quote
Old 02-12-2013, 10:00 AM   #193
Last_Paladin
Re: Project Roxy
Sorry, I do not. I also don't want to hi-jack this build thread
Old 02-12-2013, 11:55 AM   #194
PBFAB.COM
PBFAB.COM's Avatar
Re: Project Roxy
Looking good Jeff! That's a lot of work!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-12-2013, 01:35 PM   #195
Rochlow
Re: Project Roxy
Thanks, Nate!
Old 04-07-2013, 08:44 PM   #196
Rochlow
Re: Project Roxy
///Relaxed Atmosphere
Old 04-07-2013, 09:02 PM   #197
VA72C10
VA72C10
VA72C10's Avatar
Re: Project Roxy
Looks good!
Old 04-07-2013, 10:57 PM   #198
Bennett68C10
Re: Project Roxy
Nice work, glad to see some updates. Did you use the boom mat on the floor.
Keith
66 Suburban
IG: bennett68c10
Old 04-08-2013, 06:56 AM   #199
Rochlow
Re: Project Roxy
Yes I did. I really like how easy it is to use.
Old 04-21-2013, 02:34 PM   #200
Rochlow
Re: Project Roxy
