Old 02-10-2013, 07:03 PM   #1
clemsonteg
Gas smell - found problem, what's the solution?
So I went to my truck today to get something out and it smelled like someone poured gas all inside the truck. I moved the seat as far forward as I could and I pulled the carpet up and found that the center of the tank is wet all under the sending unit. Here is my question, is the top cap connected directly to the sending unit? The reason I ask is because it looks like the hard line on top of the tank may be cracked around its base. Does that require replacement of the entire sending unit and if so can it be done with the seat in the truck? Where would be the best place to pick up the part I need?
clemsonteg is offline   Reply With Quote
Old 02-10-2013, 07:39 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Gas smell - found problem, what's the solution?
Line coming out is part of the sending unit. You'll have to remove the sending unit and either replace it if it looks like it's old defective or maybe find some way to braze the line.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 02-10-2013, 07:42 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Forgot to add: You can remove the sending unit with the seat pushed as far farward as you can get it. You will have to do a search on this site for more info but be sure and use a brass drift to tap around it to remove it. Be extremely careful of sparks with metallic parts and disconnect the battery just to be safe.
06 Trailblazer
Old 02-10-2013, 08:40 PM   #4
68Cummins
68Cummins's Avatar
It is very simple to remove the sending unit. As gmsee said just tap the retainer ring. Remove the unit to inspect whats exactly leaking.
68Cummins is offline   Reply With Quote
Old 02-10-2013, 09:34 PM   #5
clemsonteg
Thanks for the info. Sounds pretty simple. Any idea where the best place is to get the parts? I found it in LMCs catalog but I know they don't always have the best parts.
Old 02-10-2013, 09:50 PM   #6
Billett
Billett's Avatar
what seat do you have? The bench really isn't that hard to pull out anyway and it would give you a lot more room to work. Not necessary, but if you have a newly reupholstered seat or some such it would be worth it IMO in case of leaks.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 02-10-2013, 10:41 PM   #7
ole dollor
ole dollor's Avatar
one more thing , make sure your tank is low enough on gas to pull the sender out. about a half tank or lower...or you will have a big leak....
ole dollor is offline   Reply With Quote
Old 02-10-2013, 10:46 PM   #8
clemsonteg
Thanks for the heads up. I actually figured that the smell is so strong because I just put gas in it the last time I drove it. I'll have to put some miles on her ( boo hoo ) before I swap it out. That will give me time to order the parts I need.
Old 02-10-2013, 11:17 PM   #9
Longhorn 70
Longhorn 70's Avatar
OR you could just syphon some off in to my tank.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 02-10-2013, 11:21 PM   #10
clemsonteg
That's a long haul for a few gallons of gas!
