Old 02-11-2013, 03:00 PM   #1
motorcritter
motorcritter's Avatar
Re: 3ott issues?
If it's an early (67-72) the rods are adjustable on the steering column end, on the later 'square' models, the adjustment is at the tranmission end of the rods. A 3/16"-7/32" rod, i.e., a drill bit, is used to center the shifter arms on the steering column. There are holes in the shifter arms that facilitate this, once you've got the arms pinned together, make sure that the transmission is in neutral and snug down the shifter rod ends. The older ones are easier- everything is on top. The newer ones, well, time to get down and dirty.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 02-11-2013, 03:05 PM   #2
Olive1970
Olive1970's Avatar
Re: 3ott issues?
This one is on a 1972. From what I understand you must be referring to where the rods hook up on the engine side of the firewall? Thats where I need to get the trans in neutral, unhook rods, lube, and center the fork while in neutral?
Gary
Slowly looking for my next 67-72 truck
Olive1970 is offline   Reply With Quote
