#26 |
GM Parts Guy
Re: 88-98 Chevy & GMC Heavy Duty Headlight Harness
Well if it's feasable, I would love to get my hands on one.
1975 Chevrolet C-10 Custom Deluxe (DD/WIP) 1989 Chevrolet C1500 reg cab stepside (Winter Truck) 1977 Harley Davidson XLH 1000 (Summer Cruiser) |
#27 |
Bump! Fall is here, and all the wildlife will be actively moving at night with the farmers in the fields harvesting there crops! Now is a great time to upgrade your headlight harness and boost your light output so you can see better at night!
#28 |
do you have any of these available? i need a couple of them. how do i contact you? your inbox is full.
cody
minitrucker with a fullsize. stock sucks!!! 95 Chevy 1/2 ton 2wd *under construction* 92 Chevy 1/2 ton 4x4 (my beater) 00 Chevy 1/2 ton 4x4 (wife's truck) |
#29 | |
I apoligize for that, I cleared some space in our PM box so you can try agian to send us a PM again! If you have any questions, please feel free to ask! Thanks, Baron |
#30 |
i am interested in the hd harness i have a 1997 gmc yukon and have a limited bumper with the fog lights in it . i also have daytime driving lights
is there a way to have fog lights come on with the head lights? i also have a set of PIAA 520's on the brush guard is there a way to wire those in for he brights? my main concern is the fog lights in the bumper i can do with out the 520's being wired in. please in box me a price and payment thru paypal would be preferred. |
#31 | |
#32 |
How much brighter will this harness make the headlights? I live out in the country & I can barely see anything with my dim lights on, I usually just drive with my brights on but even then its kind of hard to see, my lenses are a little bit yellow but not to bad.
1972 Chevy Blazer 1997 GMC Sierra 2009 Chevy Tahoe |
#33 | |
The HD Harness does truly make a big difference in light output. Due to the way that the OEM Headlight Circuit is set up, the headlights draw there power from the headlight switch; through ~16awg wire. This results in a fairly large voltage drop by the time that the power reaches the headlights. With this harness installed, it takes care of that problem. The harness supplies your headlights with direct voltage through 12AWG wire, and takes all of the load off of your headlight switch. Which results in brighter headlights, giving you more light output being that they are getting the full 13.8V+ and allowing the headlights to run at 100% intensity. Even on stock headlight bulbs, this harness WILL make them noticeably brighter. This harness along with a decent upgraded headlight bulb, will make for a WORLD of difference and truly make you feel like you are driving a different truck at night! If you have any other questions, please feel free to ask! Thanks for your time, Baron |
#34 | |
(007) aka Houdini
![]() Join Date: Mar 2010
Live life one day at a time! |
#35 |
Thank you very much for the kind words! We strive to put out the best products we possibly can, and it means a lot to us hearing positive reviews of our products from our wonderful customers!
#36 |
To the top!
#37 |
So do I just need to PM you my paypal address?
#38 |
Is VH Coachworks still open and/or around ! I am thinking about a Christmas present to myself this year !!Thanks
#39 | |
![]() If you need anything, or have any questions please don't hesitate to ask! That is correct, if you would like to order a harness just shoot us a PM with your PayPal address! |
#40 |
Bump
#41 |
The problem I'm having with my HIDs are my drivers side headlight doesn't come on sometimes in the morning and I have to sit there for a while to get it to come on. Is that something that is happening because of the thin wires I used to hook up the 4 hi relay? Will this kit fix that problem?
Austin 1996 Chevrolet K1500 Silverado ![]() 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
#42 | |
With our harness, it would be providing both headlights 13.8V+ anytime your headlight switch is on, therefore providing the HID's with 100% of the power they need to run properly. As well as providing you with an integrated 4-High feature. It's always best to run a good HD Harness when running HID's, so that they have the power they need to run properly; also so the HID's don't overload the OE harness and headlight switch. With a harness installed, if you where ever to have issues with your HID's, you'd know that the issue lies in the HID kit itself and not your truck! If you have any other questions, please feel free to ask and we'll be more then happy to help! Thanks, Baron VH Coachworks |
#43 |
Sounds good. Yea the power is definitely going from passenger side to drivers side. I'll send you a PM with more questions. Thanks.
#44 |
#45 |
Bump
#46 |
![]() Join Date: Jun 2007
send you a pm and left a message on your phone. need an order update on my 1987 4 headlight harness.
#47 |
I've been wanting to do the 4 headlight high relay on my 93 for quite some time, but never got around to it.
Questions; 1. About where do the relays mount? 2. The 2 orange wires hook straight to the battery, correct? Black is ground of course. The 2 other plugs, (activation wires for the relays from the headlight switch I assume), hook into my truck harness where? (I've never seen that style plug-in in my truck is why I ask) 3. I don't care for fuses in the headlight circuit myself, Is there a way you could replace the fuses with circuit breakers? If not, if one fuse would happen to blow for whatever reason, I would lose both headlights, correct? Meaning both right and left side, low or high beams, depending on which fuse blew.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
#48 |
bware of doing business with this vendor, he took my money and didnt send the parts. there is a thread started in the vendor reviews about it. He wont call or email me back.
#49 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Just aheads up here. I've dealt with Baron a few times and he has always been honest and up front. A year or two ago he was off the boards for 3/4 months and wasn't answering posts and then all of a sudden he was again and apologized for any problems anyone may have had because he wasn't around. By the way his products are top notch.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " In the end, we only regret the chances we didnt take " " Time is the only currency we spend without knowing the balance, use it wisely ." .. |
#50 |
Well thats good to hear, but I got $127 on the line here and no items. if he has health issues, then he needed to have somebody take care of things for him. at least answer calls and emails.
| Bookmarks |
| Tags |
| 4-hi, hd harness, headlights, hid, relay |
