Old 02-13-2013, 12:45 PM   #126
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Re: 1966 SBFS project low and go
I never actually said what the engine is in there.....
It's a factory LSA 6.2 Litre supercharged setup backed up with a 6 speed automatic
The combo is rated a 556 HP from the factory with out a tune and through all of the exhaust.
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 02-13-2013, 01:27 PM   #127
oldman3
oldman3's Avatar
Wow, the truck doesn't know what its in for....Jim
oldman3 is offline   Reply With Quote
Old 02-13-2013, 01:44 PM   #128
wutnxt
Now I just have to get it out.....and get it in....
One short sentance thats going to take weeks i am sure
Old 02-15-2013, 01:59 PM   #129
Low Elco
Muuuuaahahahaha! This oughta be awesome!
Low Elco is offline   Reply With Quote
Old 02-15-2013, 09:18 PM   #130
daverod
SSN 706
daverod's Avatar
Makes me want to go car shoppin.
daverod is offline   Reply With Quote
Old 02-16-2013, 12:27 AM   #131
Jmorales3181
Jmorales3181's Avatar
Wow that is going to be awesome. I've already been watching along but you just made things a bit more interesting. Being a Cadillac guy as well....love the ctsv engine as it is in the car never mind in one of our trucks.... Would be cool as a standard too. Checked out your 58... Top notch as well.
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 02-16-2013, 12:31 PM   #132
wutnxt
Thanks man.....it should be a good ride
Old 02-16-2013, 12:35 PM   #133
wutnxt
I looked everywhere for a LS swap and couldn't find much and I knew the caddy's had game.....But when I did research and found they had 556 HP supercharged 6.2 LS......and your 100% right I so want to test drive one now. But at 90,000 a pop I can't see one in my future anytime soon....
Old 02-16-2013, 01:02 PM   #134
wutnxt
Thanks.....I love the 58 and it's the first LS swap I have done, they feel so different to drive. I was going to put my 383 cross ram set up in it ...but when i came across the LSA I had to have it.....lol
Old 02-16-2013, 02:21 PM   #135
wutnxt
Well my shop is jammed to the roof....and the caddy had a heck of a wack and was a pain to try and get onto a hoist...So we came up with a plan B....which was take it all to my buddies shop and cut some of the front end off and pull it out topside. Now these caddies have a engine craddle and are from what i can see are made to drop out the botom. So it was a true backyard expierence....myself and 2 friends....grinders,plasma cutter,air impacts, and a John Deer Tractor.....It was a fun day
Old 02-16-2013, 02:44 PM   #136
wutnxt
Yes it rained.....but it had to be set free...
Old 02-17-2013, 12:11 AM   #137
wutnxt
I am pumped....I figure if a LSA can make a caddy do 0-60 if 3.9 seconds......and 12.3 in the quarter....It's going to be a fun ride...
Old 02-17-2013, 12:47 AM   #138
wutnxt
Well we finished the floor rough in......there is still more to go ...but the front piece is built and the hinge is mounted to the door.....the back piece is in and slides....It's a ton fab work.
Old 02-20-2013, 11:38 AM   #139
wutnxt
You know your a redneck when:
You pull a LSA supercharged set up out of a crashed car.....on a trailer....with a tractor....I guess this is the old school way to pull it.
Old 02-20-2013, 11:43 AM   #140
clemdaddy
clemdaddy's Avatar
now thats funny right there...
clemdaddy is offline   Reply With Quote
Old 02-20-2013, 11:47 AM   #141
wutnxt
It wasn't my plan A......but in the end it sure was the way to do the job...with all the damage to the car.
Old 02-20-2013, 11:52 AM   #142
wutnxt
I wasn't feeling lucky so we pulled the nose off the truck.....I took a few measurements and knew it was going to be close.....First thing we did was peel off the engine mounts and bolt on the orter built LS mounts.....thats where it all started....The mounts wouldn't clear the long slung AC pump on the passenger side...so we altered the support a bit to make it work...or so we thought
Old 02-20-2013, 12:17 PM   #143
Bomp
Bomp's Avatar
Its moments like this I start trimmin.
Thats gonna be a beast
Bomp is offline   Reply With Quote
Old 02-20-2013, 12:22 PM   #144
wutnxt
I knew a LS would fit in....the truck has a Porterbuilt cross member and mounts
But wasn't sure if the caddy pan set up would clear the rack. I was also concerned that the supercharger was going to impact the firewall.....and the 6L90 would require a massive floor cut.
Old 02-20-2013, 01:01 PM   #145
Jmorales3181
Sounds fun man! Go big or go home lol....no turning back now
Old 02-20-2013, 01:08 PM   #146
wutnxt
Spent some time under the truck yesturday and found a few more challenges......nothing that can't be fixed or altered to work. This isn't the first time I have bought a poject truck and finished it off....I think most of us have been down this road and know what comes wih it. I wasn't thinking LSA when I bought it but I was thinking maybe LS . Someone else had a differnt vision when they had it and so on....and thats how it rolls so to speak.
-The floor patches need a little TLC from the bottom side and the rockers inners aren't welded to the rocker outers
-The new wire harness needs to be pulled out... wrapped and attached to the frame
-The rear end angle is way out and is going to need to reduced by about 6 degrees
-Brake lines all need to be redone and rerouted...
Good news is all the big stuff looks like it has game.....just some clean up here and there. But hey just a small shout out to the the guy that welded a " J " beside the " PB " that is in the center of the front cross member (porter built ). Once it was up on the hoist and we stood there looking at it....my buddy is convinced it stands for "peanut butter and jam " I don't think there was anyone who didn't laugh.....it didn't help it was lunch time and we were hungry.....
Old 02-20-2013, 11:33 PM   #147
wutnxt
Well its in.....it's not finished its a trial fit but its in.....
Old 02-20-2013, 11:52 PM   #148
wutnxt
Have some issues with the Ac pump down low on the passenger side.....and i don't have the altenator bracket or altenator but it's down low on the drivers side......so i think thats not good either....lol....but working on that
Old 02-21-2013, 07:36 AM   #149
Desert.Chevy
Desert.Chevy's Avatar
Exclamation Re: 1966 SBFS project low and go
Looks good, Can I see some more of the bed. I like the engine setup, nice!
Desert.Chevy is offline   Reply With Quote
Old 02-21-2013, 03:30 PM   #150
daverod
SSN 706
daverod's Avatar
What do you mean it's not finished yet?
