Old 02-13-2013, 10:28 PM   #1
Grimm76
250 vacuum lines-
Hey:
I located a used motor out of a '72 Camaro and it got delivered today. It came with a smog pump and a total spaghetti of vacuum lines. More than I encountered when I tore into the truck the first time (old dead motor is in pieces in the bed).
My question is: is there somewhere on the forum that outlines all these different vacuum lines and what I need vs. what I can junk? I took the smog pump off and want to get this cleaned up so I can stab it in. Can someone point me in the right direction, please?
Grimm76 is offline   Reply With Quote
Old 02-13-2013, 11:51 PM   #2
JAMESCHURCH13
JamesChurch13
JAMESCHURCH13's Avatar
Re: 250 vacuum lines-
Really depends on if you have a smog inspection/what year your truck is/what you use your truck for.
HG/FTW!!!
Current vehicle collection:
1968 Chevy C-10 SWB Fleet Side, 327ci, TH350 (MD)
1987 Chevy Dually Quad Cab, 427ci, TH400
2008 Buell XB12SS, 1203cc
2006 YZ450F Wheelie Machine!
1997 Suzuki Bandit 600cc
And the Wife has some cars I pay insurance on and use to transport the kids!(01' Grand Cherokee and 06' Pontiac Grand Prix)
JAMESCHURCH13 is offline   Reply With Quote
Old 02-14-2013, 06:53 AM   #3
D13
D13's Avatar
Need to know what it's going in to.
Absolute minimum, vacuum line to distributor.
TH350 or 400 auto trans, vacuum line to trans.
Power brakes, vacuum to brakes. These are the most likely things in an early truck.
A/C doors run off vacuum but not likely present on an L6 truck.
Easiest thing is to get a diagram for the truck, and hose up accordingly.
Do you need smog? Evaporative emissions? PCV? Thermac air cleaner? Exhaust heat? EGR?
BTW if the motor is California smog out of 72 or earlier, there is a certain resto crowd that looks for correct smog pumps.
Do le't pretend
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-14-2013, 12:49 PM   #4
Grimm76
Re: 250 vacuum lines-help please
250 six going into a '76 C-10 2WD. There is a vacuum canister on the inside fender well with three lines, two of which were not connected. We got a rebuilt 2 barrel from Langdon's Stovebolt and put that on, and after some tweaking we got it through smog test (no smog pump on at that time). Shortly after that, the water pump failed, the block boiled dry, and cracked. Hence the search for a replacement 250- figuring a direct replacement would be an easy bolt-in.
The new(er) engine arrived yesterday- with several more vacuum lines leading from the block, the head, and to a functioning 1 barrel carb. All stock. Most of the fittings on the block and head allow three or four separate hoses to be attached and there are also two small metal lines from the lower passenger side of the block, one to a four-hose fitting on the intake, and the other to a vacuum-actuated valve on the exhaust manifold (I never even know that one was on there till I tore stuff apart.)
No info whatever in my Haynes manual- any help appreciated!
No automatic trans- a 4-speed with granny low (SM465?) with no plans to change trans in the immediate future.
