View Poll Results: Which Engine Combo should I choose? | |||
402 Big Block With TBI and Gear Vendors Overdrive | 31 | 28.18% | |
5.3 with 4l65e or 4l80e Tranny | 51 | 46.36% | |
6.0 with 4l80e Tranny | 16 | 14.55% | |
Duramax Detuned with 4l85e Tranny | 1 | 0.91% | |
Duramax Regular Tune with Allison Tranny | 11 | 10.00% | |
Voters: 110. You may not vote on this poll |
01-25-2013, 01:30 PM | #26 |
Re: POLL: Which engine setup for Daily Driver?
I voted for the 5.3and 4l60e combo. my reasons are that you can get a standalone wiring kit /w comp for 500 on ebay. its an easy swap to do. these are easy and cheap to find.(hell my neighbor is selling one for 1750 complete running set up). parts are easy to find. good on fuel and have a pretty good stock hp output of 295-325.
02-12-2013, 08:03 PM | #27 |
Ok everyone!! Thank you so much for all of your input and advice. As usual I took everything into consideration, realized how invaluable all of your advice and opinions were, and then went a completely different route!!!! So I just purchased 6.2 with 6l80 out of a 2008 Escalade with 48k miles on the clock. I'm sure I overpayed compared to what some of you can get engines for, but its from a really reputable yard and comes complete with extras (radiator and efans, oil cooler, tranny cooler, driveshaft, and misc other things). Now comes the fun part!!! figuring the rest out! Thanks again for all of your support!
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
02-12-2013, 10:09 PM | #28 |
Man of Mini-Talents
Ok Shawn, the least you can do for squandering all this sage advice is start a build thread. I'm curious to see how this combo does.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
02-12-2013, 10:20 PM | #29 | |
It'll Buff Out!
Nice Choice! I like the wife's 5.3/6l80 combo. keep us informed
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
02-12-2013, 10:22 PM | #30 |
I feel so used...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
02-13-2013, 12:33 AM | #31 | |
Still Learning
02-13-2013, 04:18 AM | #32 | |
The 5.3 is a fairly easy swap if converted to carbureation. They are quite plentiful as well. Good gas milage, good power, and good dependability. Posted via Mobile Device
-Bruton 1968 GMC long bed 5.7/700R4 --I'd rather push a Chevy, than drive a Ford.-- |
02-13-2013, 06:18 AM | #33 |
Collector of Projects
The GenIV motors should have a separate computer for the engine and the transmission. I am having a local (Las Vegas) shop help me with my GENIII 6.0 motor, but he swaps the 6.2/6L80e into Jeep JKs and has been featured in a bunch of magazines. He knows the details of the newer motors. He might be able to help... He's also has another members C10 in his shop for an LS1 swap... The only problem is that he's always busy...
Robbie at MoTech ... www.lswrangler.com 702.782.4434 |
02-13-2013, 10:12 AM | #34 |
All have their merits.I say go with an Edelbrock top end kit with fuel inj and add an 4l80 trans.
02-13-2013, 10:47 AM | #35 |
I'm doing the 5.3 swap right now. Lots of little things to take into consideration when doing the swap. Linkage. Getting your gauges to work. LS motors suck up oil through the PCV valve and it goes into the throttle body. Gas tank, fuel pump and fuel line set up.
I used an LS6 valley pan cover that relocates the the pcv valve and added a catch can to prevent oil getting into the throttle body. I had a tank made that has the electric pump built into the the tank with a proper ohm sending unit installed. Check the forums for water temp and oil pressure solutions. Research your computer and what you will need to remove to make it run. I'm not pessimistic but I do try to anticipate problems ahead of time. Good luck and I know you will have a great time doing your swap. |
02-14-2013, 02:03 PM | #36 |
THanks to all!! I will definitely start a build thread as soon as I get everything here and ready. I want to have as much ready to go as possible so that I can do the swap really quick!! I'll let you know when I start the build thread!!
Shawn
